For the desktop to use an icon image, the icon image file must:
Be in the proper format.
Use the proper file-naming conventions.
Use the desktop size conventions.
Be located in a directory along the icon search path.
Be called by the desktop construct using the proper syntax. For example, if you create a new control for the Front Panel, use the ICON field in the Front Panel definition to specify the icon image to use for the control.
For a color display, use X pixmap (XPM) format icon files, which typically have a.pm suffix. Otherwise, use X bitmap (XBM) format files, which typically have a .bm suffix. If transparency is used in the pixmap file, a mask file (_m.bm) is generated when the .bm file is created. See Icon Search Path for more information about how the desktop finds these files.
Each icon and backdrop image is stored as a separate file. Typically, an icon is specified with the base part of its file name. For example, an icon might be referenced with the name mail when the file is actually stored as:
/usr/dt/appconfig/icons/language/mail.l.pm
The file-naming convention of adding suffixes helps group icons by size and type. Icon names for desktop components are in these general formats:
basename.size.format
Or
basename.format
where:
basename—the image base name used to reference the image
size—a letter indicating the size: l (large) m (medium) s (small) t (tiny)
format—file format: pm (pixmap) bm (bitmap)
Table 14–1shows the recommended pixel dimensions for desktop icons.
Table 14–1 Icon Sizes and File Names| Icon Size | Bitmap Name | Pixmap Name |
| 16 by 16 (tiny) | name.t.bm | name.t.pm |
| 24 by 24 (small) | name.s.bm | name.s.pm |
| 32 by 32 (medium) | name.m.bm | name.m.pm |
| 48 by 48 (large) | name.l.bm | name.l.pm |
Table 14–2 shows the icon sizes used by the desktop components. In some cases, the size of the icon used depends on the display resolution.
Table 14–2 Desktop Components and Their Icon Sizes| Desktop Component | High Resolution | Medium Resolution | Low Resolution |
| File Manager and Application Manager (View by Name and Icon) | medium | medium | medium |
| File Manager and Application Manager (View by Name and Small Icon) | tiny | tiny | tiny |
| Main Front Panel controls | large | large | medium |
| Front Panel subpanels | medium | medium | tiny |
| Front Panel switch controls | small | small | tiny |
| Minimized windows | large | large | medium |
For example, if you specify an icon named mail for a data type, have a color display, and have set the File Manager preferences to small icons, the icon image used is mail.t.pm.
The desktop finds an icon file, or image, by searching for the file in a list of directories. This list of directories, called the icon search path, is determined by the value of several environment variables. Which variables are used and how they are put together to create the icon search path are discussed in Icon Search Path.
The default search path is:
Built-in icons: /usr/dt/appconfig/icons/language
System-wide icons: /etc/dt/appconfig/icons/language
Personal icons: HomeDirectory/.dt/icons
The desktop can access icons on remote systems. For information on creating an icon server, see Configuring Database, Icon, and Help Services.
