Resources are used by applications to set certain aspects of appearance and behavior. For example, Style Manager (dtstyle) provides resources that enable you to specify where the system looks for files containing information about color palettes:
dtstyle*paletteDirectories: /usr/dt/palettes/C HomeDirectory/.dt/palettes
App-default files for the desktop applications are located in the /usr/dt/app-defaults/language directory.
Add the resources to the file /etc/dt/config/language/sys.resources. (You may have to create the file.)
For example, if in /etc/dt/config/C/sys.resources you specify:
AnApplication*resource: value
then the resource AnApplication*resource will be set in each user's RESOURCE_MANAGER property at the next login.
For more information about Style Manager resources, see the dtstyle man page. For more information about Mailer resources, see the dtmail man page.
Resources are loaded at session startup by Session Manager. For information on how Session Manager loads the resources into the RESOURCE_MANAGER, see Loading the Session Resources.
The following Process Manager Resources are available:
sampleNowTR
postPopupMenuTR
selectNextProcessTR
selectPrevProcessTR
selectFirstProcessTR
selectLastProcessTR
killSelectedProcessTR
