The Style Manager Font dialog box enables you to select fonts (up to seven sizes) for things such as text entry and labels. It also enables you to add or delete font groups.
When a font is selected, the following resources are written to the RESOURCE_MANAGER property:
SystemFont is used for system areas, such as menu bars, menu panes, push buttons, toggle buttons, and labels. The following resource is set by SystemFont:
*FontList
—displayed
in system areas of desktop clients and other clients created using the OSF/Motif
toolkit.
UserFont is used for text entered into windows. The following resources are set by UserFont:
*Font
—supports earlier
versions of X applications
*FontSet
—the primary
setting
*XmText*FontList
—displayed
in text entry boxes
*XmTextField*FontList
—displayed
in text entry boxes
The fonts used for each selection in the Font dialog box are specified in the /usr/dt/app-defaults/Dtstyle resource file. Up to seven sizes can be specified.
NumFonts
—number of font
sizes in the Font dialog box
SystemFont[1-7]
—up to seven resources assigning a specific
font to a Font dialog box selection for SystemFont
UserFont[1-7]
font to a Font dialog box selection for UserFont
The default fonts for these resources have been chosen for readability on various displays. If you want a specific font for an application, set the font with an application font resource rather than changing these desktop fonts.
For more information about application fonts, see the DtStdAppFontNames(5) and DtStdInterfaceFontNames(5) man pages.
