Front Panel's PANEL syntax allows you to:
Change the location of the Front Panel
Change the window decoration
Set general appearance and behavior of controls
The default PANEL description is in /usr/dt/appconfig/types/language/dtwm.fp.
For additional information, see the dtfpfile(4X) man page.
Create a new Front Panel configuration file in /etc/dt/appconfig/types/language or HomeDirectory/.dt/types.
Copy the default PANEL description from /usr/dt/appconfig/types/language/dtwm.fp to the new file.
Edit the PANEL description.
The new PANEL description has precedence over the default one.
For example, the following panel is in the upper right corner.
PANEL SpecialFrontPanel
PANEL_GEOMETRY -1+1
Add the following line to the PANEL definition:
DISPLAY_CONTROL_LABELS True
Add a LABEL field to each control.
The control_name is used if no LABEL is specified.
Use the CONTROL_BEHAVIOR field in the PANEL definition to specify how the user runs a control's PUSH_ACTION. Values for the field are:
single_click—the user clicks the control to run the PUSH_ACTION
double_click—the user double-clicks the control to run the PUSH_ACTION
Creating a new Front Panel may be preferable when you want to make extensive changes.
To avoid conflict with the built-in Front Panel components, an entirely new Front Panel should use new names for the PANEL and other containers.
Create the PANEL component for the new Front Panel. Give it a unique name:
PANEL front_panel_name
Create the new boxes and controls, using the new container names.
If you want to use existing components, you must copy their definitions and change the CONTAINER_NAME value.
Choose Restart Workspace Manager from the Workspace menu.
The following example changes the default Front Panel so that its controls are organized into three rows.
Copy /usr/dt/appconfig/types/language/dtwm.fp to HomeDirectory/.dt/types/MyFrontPanel.fp. Give the file write permission.
This is the file you will edit to provide the new Front Panel.
Change the name of the Front Panel:
PANEL NewFrontPanel
Change the name of the box named Top and edit its container name:
BOX NewFrontPanelTop
CONTAINER_NAME NewFrontPanel
POSITION_HINTS first
Add box definitions for the middle and bottom rows:
BOX NewFrontPanelMiddle
POSITION_HINTS second
BOX NewFrontPanelBottom
Change the CONTAINER_NAME of the following controls to NewFrontPanelTop:
Clock
Date
Home
TextEditor
Change the CONTAINER_NAME of the following controls to NewFrontPanelBottom:
Printer
Style
Applications
Help
Trash
Change the CONTAINER_NAME of the switch to NewFrontPanelMiddle.
