Users can create and modify subpanels using the Front Panel pop-up menus.
This section discusses how to provide system-wide customization, which requires you to modify the Front Panel configuration files.
A subpanel is “attached” to a control in the Main Panel.
The attachment is done in the subpanel definition. The CONTAINER_NAME field specifies the control to which the subpanel is attached:
CONTROL control_name
SUBPANEL subpanel_name
CONTAINER_NAME control_name
Locate the control_name of the control in the Main Panel to which you want to attach the subpanel.
If the control is one of the built-in controls, its definition is in /usr/dt/appconfig/types/language/dtwm.fp.
Create a new file /etc/dt/appconfig/types/language/*.fp.
Define the subpanel:
TITLE value
KEYWORD value
Save the new configuration file.
Choose Restart Workspace Manager from the Workspace menu.
You can modify general properties (such as the title) and the contents of the built-in subpanels.
Create a new Front Panel configuration file:
System-wide: /etc/dt/appconfig/types/language/name.fp
Personal: HomeDirectory/.dt/types/name.fp.
Copy the entire default SUBPANEL definition from /usr/dt/appconfig/types/language/dtwm.fp to the new file:
Modify the subpanel definition.
For example, the following definition, placed in the file /users/janice/.dt/types/PerApps.fp, changes the name of the Personal Applications subpanel:
SUBPANEL PersAppsSubpanel
CONTAINER_NAME TextEditor
TITLE Janice's Applications
Create a Front Panel configuration file /etc/dt/appconfig/types/language/name.fp.
Define the system-wide control in the file.
Use the CONTAINER_NAME and CONTAINER_TYPE fields to specify the container for the control:
CONTAINER_NAME subpanel_name
CONTAINER_TYPE SUBPANEL
Save the configuration file.
For example, the following control defined in a new file /etc/dt/appconfig/types/language/DigitalClock.fp adds the DigitalClock (in the Desktop_Tools application group) to the Personal Applications subpanel for all users.
CONTROL DigitalClockControl
TYPE icon
CONTAINER_NAME PersAppsSubpanel
ICON Dtdgclk
PUSH_ACTION DigitalClock
PUSH_RECALL True
Use the same procedure as for removing a Main Panel control. See To Remove a Control.
Add the following field to the subpanel definition:
CONTROL_INSTALL False
The default behavior of subpanels is to close when the user chooses a control, unless the user has moved the subpanel from its original position.
The Front Panel can be configured to keep subpanels open until the user explicitly closes them.
Create a new Front Panel configuration file in:
System-wide: /etc/dt/appconfig/types/language/*.fp
Personal: HomeDirectory/.dt/types/*.fp
Copy the default PANEL definition from /usr/dt/appconfig/types/language/dtwm.fp to the new file:
PANEL FrontPanel
Add the following field to the PANEL definition:
SUBPANEL_UNPOST False
