Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Chapter 5 Registering an Application
This chapter describes how to create a registration package for an application and how to register the application onto the desktop.
When an application is fully registered onto the desktop, it has:
Application registration is a non-invasive operation to the application:
You will want to create a registration package if you are:
Overview of Application Registration
This section explains:
Note –
For a detailed example that shows how to register an existing application, see Example of Creating a Registration Package.
Features Provided by Application Registration
Application registration provides a graphical way for users to:
Figure 5–1 Application groups at the top level of Application Manager
Graphic
Figure 5–2 An application group containing an icon to start the application
Graphic
Figure 5–3 A data file's pop-up menu containing ``Open'' and ``Print''
Graphic
The Purpose of Application Registration
A registered desktop application has certain configuration files used by the desktop to provide the application's user interface:
In order for these files to be recognized and used by the desktop, they must be in certain directories specified by the desktop's search paths.
It can be difficult to administer an application when its configuration files are scattered among numerous directories. Therefore, the desktop allows an application to keep all its desktop configuration files gathered under a single directory. This grouping of files is called a registration package.
If the application is desktop smart, it supplies a registration package as part of its installation package. If you are a system administrator creating the configuration files yourself, you can create the registration package yourself.
The configuration files in the registration package are not available to the desktop because they are not located in the proper search path directories. The process of placing these files in the proper locations is called registering, or integrating, the application.
The desktop provides a tool, dtappintegrate, that performs the registration by creating symbolically linked representations of the files in the proper search path directories.
Many desktop-smart applications will automatically run dtappintegrate during the installation process. If you are a system administrator integrating an existing application, you can run it yourself after you've created the registration package.
Once an application is registered on a system's desktop, the application is available to all users on the system. If the system is configured as a desktop application server, the application will also be available to other systems throughout the network.
The dtappintegrate tool has a command-line option that reverses the process by breaking the links. This makes it easy to remove the application from the Application Manager so that it can be moved to a different application server or updated.
General Steps for Registering an Application
Note –
For a detailed example that uses these steps to create an application package, see Example of Creating a Registration Package.
  1. Modify any application resources that set fonts and colors. Otherwise, the desktop's dynamic fonts and colors will not work properly.
    See Step 1: Modifying Font and Color Resources.
  2. Create an application root location.
    See Step 2: Creating the Desktop Application Root.
  3. Create the directory structure underneath the application root.
    See Step 3: Creating the Registration Package Directories.
  4. Create the actions and data types for the application.
    See Step 4: Creating the Actions and Data Types for the Application.
  5. Put the help files in an appropriate directory.
    See Step 5: Putting the Help Files in the Registration Package.
  6. Create the icons for the application
    See Step 6: Creating Icons for the Application.
  7. Create the application group for the application.
    See Step 7: Creating the Application Group.
  8. Register the application using dtappintegrate.
    See Step 8: Registering the Application Using dtappintegrate.
Note –
For an example of modifying resources for an application, see Step 1 of the Example of Creating a Registration Package.
The desktop provides mechanisms for setting and manipulating interface fonts and window colors. In order for an application to use these mechanisms properly, you may have to modify the application's app-defaults file.
Modifying Font Resources
Note –
This section applies to applications created using OSF/Motif 1.2™ (or later versions). Style Manager cannot set interface fonts for applications written using earlier versions of OSF/Motif.
The desktop Style Manager will set interface fonts for applications created using OSF/Motif 1.2 (or later versions) if the application does not specify application-specific interface fonts.
Style Manager provides two fonts:
system font—used by system areas such as labels, menus, and buttons
user font—used for editable areas such as text fields
Each font is provided in seven sizes, labeled 1 through 7 in the Fonts dialog box. The Style Manager fonts are connected to actual fonts on the system through Style Manager resources set in /usr/dt/app-defaults/language/Dtstyle.
If you want the application to use the Style Manager fonts, you should remove any application resources that interface specify fonts. The desktop will automatically set the application's resources appropriately:
FontList—set to system font
XmText*FontList—set to user font
XmTextField*FontList—set to user font
Modifying Color Resources
Style Manager provides the ability to change application colors dynamically. The application must be an OSF/Motif 1.1 or 1.2 client. Clients written with other toolkits cannot change color dynamically; color changes take effect when the client is restarted.
The easiest way to use the dynamic colors provided by the desktop is to remove any application color resources for background and foreground color.
Note –
For an example of creating the desktop application root directory for an application, see Step 2 of Example of Creating a Registration Package.
The registration package files for the application are grouped beneath a directory called the application root, or app_root. The app_root directory used for the desktop configuration files can be the same directory as the application's installation app_root or some other location.
For example, suppose an application is installed under a directory /usr/BTE. This same directory could be used as the app_root for the desktop configuration files. However, if you are integrating an existing non-desktop smart application, create a different desktop app_root directory. This will prevent the configuration files you create from being overwritten when you update the application.
For example, a system administrator might want to create a directory /etc/desktop_approots/BTE as the desktop app_root directory.
Note –
For an example of creating the registration package directories for an application, see Step 3 of Example of Creating a Registration Package.
The registration package is the group of desktop configuration files used by the desktop to provide a graphical interface for the application.
Registration Package Contents
The desktop configuration files include:
Figure 5–4 A registration package beneath an application root directory
Graphic
The major categories of configuration fields under the app_root/dt/appconfig directory are shown in Table 5–1.
Table 5–1 Configuration Fields Major Categories
Subdirectory
Contents
types
Action and data type definition files
help
Desktop help files
icons
Bitmap and pixmap image files used by the application's actions and data types
appmanager
The directory and contents that create the application group
Each of the major categories has subdirectories for language-dependent files. Default-language files are placed in the C directory.
To Create the Registration Package
    Create these directories. If you are providing language-dependent configuration files, create a separate directory for each language. If you are supplying only one language, put the files in the C directory.
Figure 5–5 Application group at the top level of the Application Manager
Graphic
The dtappintegrate tool operates only on the desktop configuration files in the types, help, icons, and appmanager directories. The application's binary executable, app-defaults, and message catalog files are administered separately.
Note –
For an example of creating the actions and data types for an application, see Step 4 of Example of Creating a Registration Package.
Actions and data types provide a user interface for the application.
Actions and Data Types Required by an Application
Typical applications require the following action and data type definitions:
Location for Action and Data Type Definition Configuration Files
Actions and data types are defined in configuration files. The only naming requirement for files containing action and data type definitions is that they must have a .dt suffix. By convention, you may want to name the file action_name.dt or application_name.dt.
Place files containing actions and data types under the application root in the directory app_root/dt/appconfig/types/language. The default language is C.
Figure 5–6 Action and data type definition files
Graphic
Ways to Create Actions and Data Types
You can create action and data type definitions for an application in either of two ways:
To Create Actions and Data Types Using Create Action
This procedure uses the Create Action utility to create an action and data types for the application.
For more information about Create Action, use its online help or see Chapter 11, Creating Actions and Data Types Using Create Action.
  1. Open the Desktop_Apps application group and double-click Create Action.
  2. Use Create Action to create the action and data type definitions for the application and its data type.
    The configuration file created by Create Action will be written to HomeDirectory/.dt/type/action_name.dt. The action file (the executable file with the same name as the action) is placed in your home directory.
  3. Test the action using the action file created in your home directory.
  4. Copy the action definition file HomeDirectory/.dt/type/action_name.dt to the app_root/dt/appconfig/types/language directory.
  5. After the application group directory has been created (see Step 7: Creating the Application Group), copy the action file HomeDirectory/action_name to the app_root/dt/appconfig/appmanager/language/appgroup_name directory.
To Create Actions and Data Types Manually
    Create a configuration file containing the action and data type definitions for the application.
Action and data type definition files must follow the naming convention name.dt.
You can place all your action and data type definitions in one file or distribute them among multiple files. For each file, use a file name that system administrators will easily connect with your application.
Action and data type names must be one word (no embedded spaces). You can use an underscore character. By convention, the first letter of the action or data type name is capitalized. Do not use an existing action name or file name. Use a name that advanced users and system administrators will easily connect with your application.
If you want the application's icon labeled with a different name than the action name, include a LABEL field in the action definition.
For more information about creating actions and data types, see:
Note –
For an example of adding help files to a registration package, see Step 5 of Example of Creating a Registration Package.
If the application includes a desktop help volume (a help volume created with the desktop Help Developer's Kit), the help volume master file (*.sdl) should be placed in the directory app_root/appconfig/help/language.
Graphics used by the help files are usually placed in a graphics subdirectory. The graphics must be located in the same directory relative to the master help volume (*.sdl) file as when the help volume was created.
If the application does not provide a help volume, you can create one if you have the Help Developer's Kit.
There are two levels of integration of a help volume:
Note –
For an example of creating the icon files for an application, see Step 6 of Example of Creating a Registration Package.
The desktop provides default icons for actions, data types, and application groups. However, you will probably want to create unique icons for the application.
Icons are placed in the directory app_root/dt/appconfig/icons/language.
Icons Required for the Desktop
The application uses these icon images on the desktop:
Table 5–2 Naming Conventions for Icon Files
Size
Pixel Dimensions
Bitmap Name
Pixmap Name
tiny
16 by 16
basename.t.bm
basename.t.pm
medium
32 by 32
basename.m.bm
basename.m.pm
large
48 by 48
basename.l.bm
basename.l.pm
If you do not provide bitmap files, the desktop maps the color specifications of the pixmap files into black and white. However, this mapping may not produce the appearance you want.
For more information about icons, see Icon Image Files.
Note –
For an example of creating the application group, see Step 7 of Example of Creating a Registration Package.
Once you have created the action and data type definitions for the application, you must create the configuration files responsible for creating what the user actually sees—the application group and its contents.
The application group is a directory at the top level of the Application Manager (see Figure 5–1).
There are three steps to creating the application group:
Creating the Application Group Directory
To create an application group, create the directories in the registration package under appmanager, as shown in Figure 5–7.
Figure 5–7 The appmanager directory
Graphic
Application Group Name
The <appgroup_name> in Figure 5–7 is the name for the application group.
Figure 5–8 The application group name (<appgroup_name>)
Graphic
The name can be any allowable file (directory) name. Use a name that describes the application.
Configuring the Application Group To Use a Unique Icon
The desktop provides a default application-group icon. However, you will probably want to provide a custom icon.
If you want to provide a unique icon for the application group, you must create:
Figure 5–9 How an application group gets a unique icon
Graphic
You should also create an Open and Print action for the application group data type:
ACTION Open
 	ARG_TYPE			Media_ToolsAppGroup
 	TYPE				MAP
 	MAP_ACTION		OpenAppGroup
ACTION Print
 	TYPE				MAP
 	MAP_ACTION		PrintAppGroup
OpenAppGroup and PrintAppGroup actions are built-in actions defined in /usr/dt/appconfig/types/language/dtappman.dt.
Creating the Contents of the Application Group
The most important item in the application group is an icon to start the application (an action icon). If the application group contains a suite of applications, there is usually an icon for each application.
In addition to one or more action icons, the application group may contain:
Creating the Action File (Application Icon)
The application group should contain an icon that launches the application. If the group supplies a suite of applications, there should be an icon for each one. These icons are called application icons, or action icons, since they represent an underlying action.
An action icon is created by creating an executable file with the same name as the action it will run:
app_root/dt/appconfig/appmanager/appgroup_name/action_name
The file is called an action file, because its purpose is to create a visual representation of the underlying action.
For example, if you've created an action named BestTextEditor that runs the BestTextEditor application, you would create an executable file named BestTextEditor. In File Manager and the Application Manager, the action file will use the icon image specified in the action definition.
Figure 5–10 illustrates the relationship between the action definition, action file, and actual entry in the Application Manager window.
Figure 5–10 The application icon is a file in the application group
Graphic
Read Me Files
The desktop provides a README data type that you can use for your application's README files. Use one of these naming conventions:
Creating a Specialized Front Panel Control
In most cases, you do not need to provide a Front Panel control definition; the user can add the application to the Front Panel by dropping the action icon on the Install Icon control in a subpanel.
You might want to create a Front Panel configuration file containing a control definition for your application if you want users to be able to install a control that behaves differently than the action icon—for example, if the control monitors a file and changes appearance when the monitored file changes.
Front Panel configuration files are placed in the app_root/dt/appconfig/types/language directory. The naming convention is name.fp.
If you supply a configuration file containing a control, the user can add the control to a subpanel by dropping the *.fp file on the Install Icon control in the subpanel.
For example, the following definition can be placed in a Front Panel configuration file in the application group. If the user drops this file on an Install Icon control in a subpanel, a control is created in the subpanel that runs a single instance of the BestTextEditor application. If BestTextEditor is already running, the window is moved to the top of the window stack in the current workspace.
CONTROL BestTextEditorControl
 	TYPE						icon
 	ICON						BTEFPanel
 	PUSH_RECALL				True
 	CLIENT_NAME				BTEd
 	PUSH_ACTION				BTEditor
 	DROP_ACTION				BTEditor
 	HELP_STRING				Starts the BestTextEditor application.
For additional information about creating Front Panel configuration files, see:
Note –
For an example of registering an application, see Step 8 of Example of Creating a Registration Package.
Once you've created a registration package under an application root, you are ready to perform the actual application registration.
Application registration creates links between the registration package and the directories located along the desktop search paths (see How dtappintegrate Integrates Applications).
To Register an Application with dtappintegrate
If the application is desktop-smart, dtappintegrate is usually run automatically as the final step in the installation process. If it is not run automatically, or if you have created the configuration files to integrate a non-desktop smart application, then you can run dtappintegrate manually.
  1. Log in as root.
  2. Run the command:
    	/usr/dt/bin/dtappintegrate -s  app_root
    where app_root is the desktop application root directory. For more information, see the dtappintegrate(1) man page.
  3. Open the Desktop_Tools application group and double-click Reload Applications.
  4. Verify that the application is properly registered:
    1. Display the top level of the Application Manager. The new application group should appear in the Application Manager.
    2. Open the application group and double-click the action icon.
Syntax and Options for dtappintegrate
dtappintegrate -s app_root [-t target_path ] [-l language ] [-u]
-s app_root
Required parameter, specifies the application root under which the appication has been installed.
-t target_path
Optional parameter, defaults to the system location /etc/dt/appconfig. Specifies the location to which the desktop configuration files are linked. You must use a location on the application search path.
-l language
Optional parameter, defaults to all languages. Specifies which language-dependent desktop configuration files to integrate.
-u
Optional parameter, un-integrates the application, removing all the links set up during integration.
The function of dtappintegrate is to set up links between the installed files and the locations where the desktop looks for configuration files.
dtappintegrate creates symbolic links from the action and data type definition files in the registration package to the system-wide directory along the action database help search path. This is done by creating links from
app_root/dt/appconfig/types/language/*.dt
to
/etc/dt/appconfig/types/language/*.dt
Help Information Files
dtappintegrate creates symbolic links from the help files in the registration package to the system-wide directory along the help search path. This is done by creating links from
app_root/dt/appconfig/help/language/help_file.sdl
to
/etc/dt/appconfig/help/language/help_file.sdl
Icon Files
dtappintegrate creates symbolic links from the icon files in the registration package to the system-wide directory along the icon search path. This is done by creating links from
app_root/dt/appconfig/icons/language/icon_files
to
/etc/dt/appconfig/icons/language/icon_files
Application Group
To place the application group for the application into the top level of Application Manager, dtappintegrate creates a link between the application group directory in the registration package and the system-wide location along the application search path. This is done by creating links from the directory
to
/etc/dt/appconfig/appmanager/language/appgroup_name
The following steps create a registration package for an existing, non-desktop smart application named BestTextEditor.
Information You Need to Know About ``BestTextEditor''
The example assumes the following facts about the BestTextEditor application:
Steps to Registering ``BestTextEditor''
The following step-wise procedure registers BestTextEditor.
  1. Modify font and color resources.
    In BestTextEditor's app-defaults file, remove resources that set:
    • Fonts for text
    • Colors for foreground and background
  2. Create the application root.
    Create the directory:
    If you are integrating an existing application, you should create the application root directory elsewhere than in the installation location for the application; otherwise, the configuration files you create may be removed when you update the application.
  3. Create the registration package directories.
    Create these directories:
    	/desktop_approots/BTE/dt/appconfig/types/C
     	/desktop_approots/BTE/dt/appconfig/help/C
     	/desktop_approots/BTE/dt/appconfig/icons/C
     	/desktop_approots/BTE/dt/appconfig/appmanager/C/BestTextEditor
    1. Create the configuration file for the action and data type definitions:
          /desktop_approots/BTE/dt/appconfig/types/C/BTE.dt
    2. Create the action definition for running BestTextEditor:
      ACTION BTEditor
              WINDOW_TYPE    NO_STDIO
              ICON           BTERun
              DESCRIPTION    Double-click this icon or drop \
                             a BTE data file on it to run \
                             BestTextEditor.
              EXEC_STRING    /usr/BTE/BTEd %Arg_1%
    3. Create the data type for *.bte files:
      DATA_ATTRIBUTES BTEDataFile
              DESCRIPTION				BestTextEditor data file.
              ICON						BTEData
              ACTIONS					Open,Print
              DATA_CRITERIA BTEDataFileCriteria1
              DATA_ATTRIBUTES_NAME    BTEDataFile
              NAME_PATTERN    *.bte
              MODE        f
    4. Create the data type for *.tpl files:
      		DATA_ATTRIBUTES BTETemplateFile
       				DESCRIPTION			BestTextEditor template file.
       				ICON					BTETempl
       				ACTIONS				Open
       		DATA_CRITERIAL BTETemplateFileCriteria1
       				DATA_ATTRIBUTES_NAME			BTETemplateFile
       				NAME_PATTERN						*.tpl
       				MODE									f
    5. Create the Open action for *.bte files.
      		ACTION Open
       				ARG_TYPE			BTEDataFile
       				TYPE				MAP
       				MAP_ACTION		BTEditor
    6. Create the Print action for *.bte files.
      Here are simple Print actions that will print the data files. These actions require a value for the LPDEST environment variable and ignore the -s print option. (If LPDEST isn't set, the action may fail.)
      		ACTION Print
       				TYPE					MAP
       				MAP_ACTION			BTEPrintData
      		ACTION BTEPrintData
       		{ 		WINDOW_TYPE				NO_STDIO
       				EXEC_STRING				BTEPrint -d $LPDEST %Arg_1%
      Here is another version of the BTEPrintData action and an accompanying script. Together, they handle situations where LPDEST is not set or if silent printing is requested.
      		ACTION BTEPrintData
       				EXEC_STRING				/usr/BTE/bin/BTEenvprint \
       											%(File)Arg_1%
      The contents of the /usr/BTE/bin/BTEenvprint script are:
      		# BTEenvprint
       		#!/bin/sh
       		DEST=””
       		SILENT=””
       		if [ $LPDEST ] ; then
       			DEST=”-d $LPDEST”
       		fi
       		BTEPrint $DEST SILENT $1
    7. Create the Open action for *.tpl files:
      		ACTION Open
       				ARG_TYPE			BTETemplateFile
       				TYPE				MAP
       				MAP_ACTION		BTEditor
    8. Create the Print action for *.tpl files:
      		ACTION Print
       				ARG_TYPES		BTETemplateFile
       				TYPE				MAP
       				MAP_ACTION		NoPrint
      NoPrint is a built-in action that displays a dialog box telling the user the file cannot be printed.
  5. Put the help files into the registration package.
    1. Place the help files in the following locations:
      		/desktop_approots/BTE/dt/appconfig/help/C/BTEHelp.sdl
       		/desktop_approots/BTE/dt/appconfig/help/C/graphics/BTE1.xwd
       		/desktop_approots/BTE/dt/appconfig/help/C/graphics/BTE2.xwd
    2. Create the file:
      		/desktop_approots/BTE/dt/appconfig/types/C/BTEhelp.dt.
      Put the following action definition in the file:
      		ACTION BTEHelp
              EXEC_STRING    /usr/dt/bin/dthelpview -helpVolume \
                  BTEHelp.sdl
              DESCRIPTION    Opens the BestTextEditor help volume.
  6. Create icons for the application.
    Use Icon Editor to create the icons. Table 5–3 shows the size guidelines to use.
    Table 5–3 Icon Size Guidelines
    Name
    Size
    basename.t.pm
    16 by 16
    basename.m.pm
    32 by 32
    basename.l.pm
    48 by 48
    Create these icon files in the directory /desktop_approots/BTE/dt/appconfig/icons/C:
    • Icons to represent the action that runs the application: BTERun.t.pm, BTERun.m.pm, BTERun.l.pm
    • Icons to represent *.bte files: BTEData.t.pm, BTEData.m.pm,
    • Icons to represent *.tpl files: BTETempl.t.pm, BTETempl.m.pm
    • Icons to represent the application group (used in step 7): BTEApp.t.pm, BTEApp.m.pm
  7. Create the application group.
    1. If you haven't already done so, create the directory.
    2. This step is optional. It provides a unique icon for the application group icon by creating a data type and associated actions for the application group. If you omit this step, the application group will use the default icon.
      Add the following data type and action definitions to the file /desktop_approots/BTE/dt/appconfig/types/C/BTE.dt. The data type specifies the icon to be used by the BestTextEditor application group. The actions provide the same Open and Print behavior as the built-in application groups.
      		DATA_ATTRIBUTES BestTextEditorAppGroup
       				ACTIONS		OpenInPlace,OpenNewView
       				ICON			BTEApp
      		DATA_CRITERIA BestTextEditorAppGroupCriterial
       				DATA_ATTRIBUTES_NAME	BestTextEditorAppGroup
       				MODE							d
       				PATH_PATTERN				*/appmanager/*/BestTextEditor
      		ACTION Open
       				ARG_TYPE				BestTextEditorAppGroup
       				TYPE					MAP
      		ACTION Print
       				TYPE					MAP
    3. Create an icon in the application group that will start the application. To do this, create the file:
      		/desktop_approots/BTE/dt/appconfig/appmanager/C \
       		/BestTextEditor/BTEditor
      and make the file executable.
    4. Create the action file in the application group that will open the help volume. To do this, create the file:
       		/BestTextEditor/BTEHelp
    5. Put other files into the application group; for example, “read me” files, sample data and template files.
  8. Register the application.
    In a terminal emulator window:
    1. Log in as root.
    2. Run the command:
      		/usr/dt/bin/dtappintegrate -s /desktop_approots/BTE
