dtappintegrate -s app_root [-t target_path ] [-l language ] [-u]
-s app_root |
Required parameter, specifies the application root under which the appication has been installed. |
-t target_path |
Optional parameter, defaults to the system location /etc/dt/appconfig. Specifies the location to which the desktop configuration files are linked. You must use a location on the application search path. |
-l language |
Optional parameter, defaults to all languages. Specifies which language-dependent desktop configuration files to integrate. |
-u |
Optional parameter, un-integrates the application, removing all the links set up during integration. |
