You can set display-specific resources for all desktop users on the system. Also, users can set display-specific resources limited to their own session. This enables you to specify resources depending upon which display the user uses to log in to the desktop.
To set display-specific resources for all desktop users on the system, create the file /etc/dt/config/language/sys.resources that specifies the display-specific resources.
To set personal display-specific resources, specify the resource in HomeDirectory/.Xdefaults.
You delimit these resources by enclosing them in cpp
conditional statements. A DISPLAY_displayname
macro is defined depending upon the value of the $DISPLAY variable. This is done by converting all . (period)
and : (colon) characters to _ (underscores), stripping off any screen specification,
and finally prefixing DISPLAY_ to the
result.
For example, a $DISPLAY of :0 would be DISPLAY_0, and
a $DISPLAY of blanco.gato.com:0.0 would be DISPLAY_blanco_gato_com_0. The resulting
value can be used as part of a cpp test in a session resource
file. For example, if in /etc/dt/config/C/sys.resources
you specify:
Myapp*resource: value
#ifdef DISPLAY_blanco_gato_com_0 Myapp*resource: specialvalue1 #endif
#ifdef DISPLAY_pablo_gato_com_0 Myapp*resource: specialvalue2 #endif
the resource MyApp*resource will be set in RESOURCE_MANAGER to specialvalue1 when the user logs in on display blanco.gato.com:0; specialvalue2 when the user logs in on pablo.gato.com:0; and value when the user logs in on another display.
