Choose Failsafe Session from the Solaris CDE Login screen's Option menu to bypass the normal Xsession startup to look at error logs and fix possible user dot file problems. Table 3–1 shows the error logs and their locations.
Table 3–1 Error Log Locations
Some errors are also displayed in the System Console window. If the System Console window is not running, the fallback console log file name is wscon with the time/display code concatenated. For example:
/usr/tmp/wsconAAAa004EE:0.0
