Solaris Advanced User's Guide
Undoing the Previous Command
If you make a mistake in vi or if you just change your mind after an operation is completed, you can undo your last command by pressing u immediately after the command. You do not need to press Esc after you type u. By pressing u a second time you undo the undo.
