By default, the code generated by rpcgen is not MT safe. It uses unprotected global variables and returns results in the form of static variables. The -M flag generates MT-safe code that can be used in a multithreaded environment. This code can be used with the C-style flag, the ANSI C flag, or both.
An example of an MT-safe program with this interface follows. The rpcgen protocol file is msg.x, shown in the following code example.
program MESSAGEPROG {
version PRINTMESSAGE {
int PRINTMESSAGE(string) = 1;
} = 1;
} = 0x4001;
A string is passed to the remote procedure, which prints it and returns the length of the string to the client. The MT-safe stubs are generated with the rpcgen -M msg.x command.
Client-side code that could be used with this protocol file is shown in the following code example.
#include "msg.h"
void
messageprog_1(host)
char *host;
CLIENT *clnt;
enum clnt_stat retval_1;
int result_1;
char * printmessage_1_arg;
clnt = clnt_create(host, MESSAGEPROG,
PRINTMESSAGE,
"netpath");
if (clnt == (CLIENT *) NULL) {
clnt_pcreateerror(host);
exit(1);
printmessage_1_arg =
(char *) malloc(256);
strcpy(printmessage_1_arg, "Hello World");
retval_1 = printmessage_1(&printmessage_1_arg,
&result_1,clnt);
if (retval_1 != RPC_SUCCESS) {
clnt_perror(clnt, "call failed");
printf("result = %d\n", result_1);
clnt_destroy(clnt);
main(argc, argv)
int argc;
char *argv[];
char *host;
if (argc < 2) {
printf("usage: %s server_host\n", argv[0]);
exit(1);
host = argv[1];
messageprog_1(host);
A pointer to both the arguments and the results needs to be passed in to the rpcgen-generated code in order to preserve re-entrancy. The value returned by the stub function indicates whether this call is a success or a failure. The stub returns RPC_SUCCESS if the call is successful. Compare the MT-safe client stub, generated with the -M option, and the MT-unsafe client stub shown in Example 3–16. The client stub that is not MT-safe uses a static variable to store returned results and can use only one thread at a time.
int *
printmessage_1(argp, clnt)
char **argp;
CLIENT *clnt;
static int clnt_res;
memset((char *)&clnt_res, 0,
sizeof (clnt_res));
if (clnt_call(clnt, PRINTMESSAGE,
(xdrproc_t) xdr_wrapstring,
(caddr_t) argp,
(xdrproc_t) xdr_int, (caddr_t)
&clnt_res,
TIMEOUT) != RPC_SUCCESS) {
return (NULL);
return (&clnt_res);
The server side code is shown in the following example.
When compiling a server that uses MT-safe mode, you must link in the threads library. To do so, specify the -lthread option in the compile command.
#include "msg.h"
#include <syslog.h>
bool_t
printmessage_1_svc(argp, result, rqstp)
char **argp;
int *result;
struct svc_req *rqstp;
int retval;
if (*argp == NULL) {
syslog(LOG_INFO, "argp is NULL\n");
*result = 0;
else {
syslog("argp is %s\n", *argp);
*result = strlen (*argp);
retval = 1;
return (retval);
int
messageprog_1_freeresult(transp, xdr_result, result)
SVCXPRT *transp;
xdrproc_t xdr_result;
caddr_t result;
* Insert additional freeing code here,
* if needed
(void) xdr_free(xdr_result, result);}
The server-side code should not use statics to store returned results. A pointer to the result is passed in and this should be used to pass the result back to the calling routine. A return value of 1 indicates success to the calling routine, while 0 indicates a failure.
In addition, the code generated by rpcgen also generates a call to a routine to free any memory that might have been allocated when the procedure was called. To prevent memory leaks, any memory allocated in the service routine needs to be freed in this routine. messageprog_1_freeresult() frees the memory.
Normally, xdr_free() frees any allocated memory for you. In this example, no memory was allocated, so no freeing needs to take place.
The following add.x file shows the use of the -M flag with the C-style and ANSI C flag.
program ADDPROG {
version ADDVER {
int add(int, int) = 1;
} = 1;
}= 199;
This program adds two numbers and returns its result to the client. rpcgen is invoked on it, with the rpcgen -N -M -C add.x command. The following example shows the multithreaded client code to call this code.
* This client-side main routine
* starts up a number of threads,
* each of which calls the server
* concurrently.
#include "add.h"
CLIENT *clnt;
#define NUMCLIENTS 5
struct argrec {
int arg1;
int arg2;
/* Keeps count of number of
* threads running
int numrunning;
mutex_t numrun_lock;
cond_t condnum;
void
addprog(struct argrec *args)
enum clnt_stat retval;
int result;
/* call server code */
retval = add_1(args->arg1, args->arg2,
&result, clnt);
if (retval != RPC_SUCCESS) {
} else
printf("thread #%x call succeeded,
result = %d\n", thr_getself(),
result);
/* decrement the number of running
* threads
mutex_lock(&numrun_lock);
numrunning--;
cond_signal(&condnum);
mutex_unlock(&numrun_lock);
thr_exit(NULL);
main(int argc, char *argv[])
char *host;
struct argrec args[NUMCLIENTS];
int i;
thread_t mt;
int ret;
if (argc < 2) {
argv[0]);
exit(1);
host = argv[1];
clnt = clnt_create(host, ADDPROG, ADDVER,
"netpath");
exit(1);
mutex_init(&numrun_lock, USYNC_THREAD, NULL);
cond_init(&condnum, USYNC_THREAD, NULL);
numrunning = 0;
/* Start up separate threads */
for (i = 0; i < NUMCLIENTS; i++) {
args[i].arg1 = i;
args[i].arg2 = i + 1;
ret = thr_create(NULL, NULL, addprog,
(char *) &args[i],
THR_NEW_LWP, &mt);
if (ret == 0)
numrunning++;
/* are any threads still running ? */
while (numrunning != 0)
cond_wait(&condnum, &numrun_lock);
clnt_destroy(clnt);}
The server-side procedure is shown in the following example.
add_1_svc(int arg1, int arg2,
int *result, struct svc_req *rqstp)
bool_t retval;
/* Compute result */
*result = arg1 + arg2;
retval = 1;
return (retval);
/* Routine for freeing memory that may
* be allocated in the server procedure
int
addprog_1_freeresult(SVCXPRT *transp,
xdrproc_t xdr_result,
caddr_t result)
