The simplified interfaces are used to make remote procedure calls to routines on other machines, and specify only the type of transport to use. The routines at this level are used for most applications. Descriptions and code samples are in the section Simplified Interface.
Table 2–1 RPC Routines—Simplified Level
Routine |
Function |
Registers a procedure as an RPC program on all transports of the specified type |
rpc_call() |
Remotely calls the specified procedure on the specified remote host |
Broadcasts a call message across all transports of the specified type |
