SPARC Assembly Language Reference Manual
2.3.8 Operators and Expressions
The operators described in Table 2–3 are recognized in constant expressions.
Table 2–3
Binary
Operators
Unary
Operators
Integer addition
(No effect)
Integer subtraction
2's Complement
Integer multiplication
1's Complement
Integer division
%lo(address)
Extract least significant 10 bits as computed by: (address & 0x3ff)
Modulo
%hi(address)
Extract most significant 22 bits as computed by: (address >>10)
Exclusive OR
%r_disp32
%r_disp64
Used in Sun compiler-generated code only to instruct the assembler to generate specific relocation information for the given expression.
Left shift
%r_plt32
%r_plt64
Right shift
Bitwise AND
Bitwise OR
Since these operators have the same precedence as in the C language, put expressions in parentheses to avoid ambiguity.
To avoid confusion with register names or with the %hi, %lo, %r_disp32/64, or %r_plt32/64 operators, the modulo operator % must not be immediately followed by a letter or digit. The modulo operator is typically followed by a space or left parenthesis character.
