SPARC Assembly Language Reference Manual
E.6 UltraSPARC and VIS Instruction Set Extensions
This section describes extensions that require SPARC-V9. The extensions support enhanced graphics functionality and improved memory access efficiency.
Note –
SPARC-V9 instruction set extensions used in executables may not be portable to other SPARC-V9 systems.
E.6.1 Graphics Data Formats
The overhead of converting to and from floating-point arithmetic is high, so the graphics instructions are optimized for short-integer arithmetic. Image components are 8 or 16 bits. Intermediate results are 16 or 32 bits.
E.6.2 Eight-bit Format
A 32-bit word contains pixels of four unsigned 8-bit integers. The integers represent image intensity values (Graphic, G, B, R). Support is provided for band interleaved images (store color components of a point), and band sequential images (store all values of one color component).
E.6.3 Fixed Data Formats
A 64-bit word contains four 16-bit signed fixed-point values. This is the fixed 16-bit data format.
A 64-bit word contains two 8-bit signed fixed-point values. This is the fixed 32-bit data format.
Enough precision and dynamic range (for filtering and simple image computations on pixel values) can be provided by an intermediate format of fixed data values. Pixel multiplication is used to convert from pixel data to fixed data. Pack instructions are used to convert from fixed data to pixel data (clip and truncate to an 8-bit unsigned value). The FPACKFIX instruction supports conversion from 32-bit fixed to 16-bit fixed. Rounding is done by adding one to the rounding bit position. You should use floating-point data to perform complex calculations needing more precision or dynamic range.
E.6.4 SHUTDOWN Instruction
All outstanding transactions are completed before the SHUTDOWN instruction completes.
Table E–13
SPARC
Mnemonic
Argument List
Description
SHUTDOWN
shutdown
shutdown to enter power down mode
E.6.5 Graphics Status Register (GSR)
You use ASR 0x13 instructions RDASR and WRASR to access the Graphics Status Register.
Table E–14
SPARC
Mnemonic
Argument List
Description
RDASR
WRASR
rdasr
wrasr
%gsr, regrd
regrs1, reg_or_imm, %gsr
read GSR
write GSR
E.6.6 Graphics Instructions
Unless otherwise specified, floating-point registers contain all instruction operands. There are 32 double-precision registers. Single-precision floating-point registers contain the pixel values, and double-precision floating-point registers contain the fixed values.
The opcode space reserved for the Implementation-Dependent Instruction1 (IMPDEP1) instructions is where the graphics instruction set is mapped.
Partitioned add/subtract instructions perform two 32-bit or four 16-bit partitioned adds or subtracts between the source operands corresponding fixed point values.
Table E–15
SPARC
Mnemonic
Argument List
Description
FPADD16
FPADD16S
FPADD32
FPADD32S
FPSUB16
FPSUB16S
FPSUB32
FPSUB32S
fpadd16
fpadd16s
fpadd32
fpadd32s
fpsub16
fpsub16s
fpsub32
fpsub32s
fregrs1, fregrs2, fregrd
four 16-bit add
two 16-bit add
two 32-bit add
one 32-bit add
four 16-bit subtract
two 16-bit subtract
two 32-bit subtract
one 32-bit subtract
Pack instructions convert to a lower pixel or precision fixed format.
Table E–16
SPARC
Mnemonic
Argument List
Description
FPACK16
FPACK32
FPACKFIX
FEXPAND
FPMERGE
fpack16
fpack32
fpackfix
fexpand
fpmerge
fregrs2, fregrd
fregrs2, fregrd
fregrs2, fregrd
four 16-bit packs
two 32-bit packs
four 16-bit packs
four 16-bit expands
two 32-bit merges
Partitioned multiply instructions have the following variations.
Table E–17
SPARC
Mnemonic
Argument List
Description
FMUL8x16
FMUL8x16AU
FMUL8x16AL
FMUL8SUx16
FMUL8ULx16
FMULD8SUx16
FMULD8ULx16
fmul8x16
fmul8x16au
fmul8x16al
fmul8sux16
fmul8ulx16
fmuld8sux16
fmuld8ulx16
8x16-bit partition
8x16-bit upper Graphic partition
8x16-bit lower Graphic partition
upper 8x16-bit partition
lower unsigned 8x16-bit partition
Alignment instructions have the following variations.
Table E–18
SPARC
Mnemonic
Argument List
Description
ALIGNADDRESS
ALIGNADDRESS_LITTLE
FALIGNDATA
alignaddr
alignaddrl
faligndata
regrs1, regrs2, regrd
find misaligned data access address
same as above, but little-endian
do misaligned data, data alignment
Logical operate instructions perform one of sixteen 64-bit logical operations between rs1 and rs2 (in the standard 64-bit version).
Table E–19
SPARC
Mnemonic
Argument List
Description
FZERO
FZEROS
FONE
FONES
FSRC1
fzero
fzeros
fone
fones
fsrc1
fregrd
fregrd
fregrd
fregrd
fregrs1, fregrd
zero fill
zero fill, single precision
one fill
one fill, single precision
copy src1
FSRC1S
FSRC2
FSRC2S
FNOT1
FNOT1S
fsrc1s
fsrc2
fsrc2s
fnot1
fnot1s
fregrs1, fregrd
fregrs2, fregrd
fregrs2, fregrd
fregrs1, fregrd
fregrs1, fregrd
copy src1, single precision
copy src2
copy src2, single precision
negate src1, 1's complement
same as above, single precision
FNOT2
FNOT2S
FOR
FORS
FNOR
fnot2
fnot2s
for
fors
fnor
fregrs2, fregrd
fregrs2, fregrd
negate src2, 1's complement
logical OR
logical OR, single precision
logical NOR
FNORS
FAND
FANDS
FNAND
FNANDS
fnors
fand
fands
fnand
fnands
logical NOR, single precision
logical AND
logical AND, single precision
logical NAND
logical NAND, single precision
FXOR
FXORS
FXNOR
FXNORS
FORNOT1
fxor
fxors
fxnor
fxnors
fornot1
logical XOR
logical XOR, single precision
logical XNOR
logical XNOR, single precision
negated src1 OR src2
FORNOT1S
FORNOT2
FORNOT2S
FANDNOT1
fornot1s
fornot2
fornot2s
fandnot1
src1 OR negated src2
negated src1 AND src2
FANDNOT1S
FANDNOT2
FANDNOT2S
fandnot1s
fandnot2
fandnot2s
src1 AND negated src2
Pixel compare instructions compare fixed-point values in rs1 and rs2 (two 32 bit or four 16 bit)
Table E–20
SPARC
Mnemonic
Argument List
Description
FCMPGT16
FCMPGT32
FCMPLE16
FCMPLE32
fcmpgt16
fcmpgt32
fcmple16
fcmple32
fregrs1, fregrs2, regrd
4 16-bit compare, set rd if src1>src2
2 32-bit compare, set rd if src1>src2
4 16-bit compare, set rd if src1≤src2
2 32-bit compare, set rd if src1≤src2
FCMPNE16
FCMPNE32
FCMPEQ16
FCMPEQ32
fcmpne16
fcmpne32
fcmpeq16
fcmpeq32
4 16-bit compare, set rd if src1≠src2
2 32-bit compare, set rd if src1≠src2
4 16-bit compare, set rd if src1=src2
2 32-bit compare, set rd if src1=src2
Edge handling instructions handle the boundary conditions for parallel pixel scan line loops.
Table E–21
SPARC
Mnemonic
Argument List
Description
EDGE8
EDGE8L
EDGE16
edge8
edge8l
edge16
8 8-bit edge boundary processing
same as above, little-endian
4 16-bit edge boundary processing
EDGE16L
EDGE32
EDGE32L
edge16l
edge32
edge32l
2 32-bit edge boundary processing
Pixel component distance instructions are used for motion estimation in video compression algorithms.
Table E–22
SPARC
Mnemonic
Argument List
Description
PDIST
pdist
8 8-bit components, distance between
The three-dimensional array addressing instructions convert three- dimensional fixed-point addresses (in rs1) to a blocked-byte address. The result is stored in rd.
Table E–23
SPARC
Mnemonic
Argument List
Description
ARRAY8
ARRAY16
ARRAY32
array8
array16
array32
convert 8-bit 3-D address to blocked byte address
same as above, but 16-bit
same as above, but 32-bit
E.6.7 Memory Access Instructions
These memory access instructions are part of the SPARC-V9 instruction set extensions.
Table E–24
SPARC
imm_asi
Argument List
Description
STDFA
STDFA
STDFA
STDFA
ASI_PST8_P
ASI_PST8_S
ASI_PST8_PL
ASI_PST8_SL
stda fregrd, [fregrs1] regmask, imm_asi
eight 8-bit conditional stores to:
primary address space
secondary address space
primary address space, little endian
secondary address space, little endian
STDFA
STDFA
STDFA
STDFA
ASI_PST16_P
ASI_PST16_S
ASI_PST16_PL
ASI_PST16_SL
four 16-bit conditional stores to:
STDFA
STDFA
STDFA
STDFA
ASI_PST32_P
ASI_PST32_S
ASI_PST32_PL
ASI_PST32_SL
two 32-bit conditional stores to:
Note –
To select a partial store instruction, use one of the partial store ASIs with the STDA instruction.
Table E–25
SPARC
imm_asi
Argument List
Description
LDDFA
STDFA
ASI_FL8_P
ldda [reg_addr] imm_asi, freqrd
stda freqrd, [reg_addr] imm_asi
8-bit load/store from/to:
LDDFA
STDFA
ASI_FL8_S
ldda [reg_plus_imm] %asi, freqrd
stda [reg_plus_imm] %asi
LDDFA
STDFA
ASI_FL8_PL
LDDFA
STDFA
ASI_FL8_SL
LDDFA
STDFA
ASI_FL16_P
16-bit load/store from/to:
LDDFA
STDFA
ASI_FL16_S
LDDFA
STDFA
ASI_FL16_PL
LDDFA
STDFA
ASI_FL16_SL
Note –
To select a short floating-point load and store instruction, use one of the short ASIs with the LDDA and STDA instructions.
Table E–26
SPARC
imm_asi
Argument List
Description
LDDA
LDDA
ASI_NUCLEUS_QUAD_LDD
ASI_NUCLEUS_QUAD_LDD_L
[reg_addr] imm_asi, regrd
[reg_plus_imm] %asi, regrd
128-bit atomic load
128-bit atomic load, little endian
LDDFA
STDFA
ASI_BLK_AIUP
64-byte block load/store from/to:
primary address space, user privilege
LDDFA
STDFA
ASI_BLK_AIUS
stda fregrd, [reg_plus_imm] %asi
secondary address space, user privilege.
LDDFA
STDFA
ASI_BLK_AIUPL
primary address space, user privilege, little endian
LDDFA
STDFA
ASI_BLK_AIUSL
secondary address space, user privilege little endian
LDDFA
STDFA
ASI_BLK_P
LDDFA
STDFA
ASI_BLK_S
LDDFA
STDFA
ASI_BLK_PL
LDDFA
STDFA
ASI_BLK_SL
LDDFA
STDFA
ASI_BLK_COMMIT_P
64-byte block commit store to primary address space
LDDFA
STDFA
ASI_BLK_COMMIT_S
64-byte block commit store to secondary address space
Note –
To select a block load and store instruction, use one of the block transfer ASIs with the LDDA and STDA instructions.
