To view the status of a hot spare pool and its hot spares, use one of the following methods:
From the Enhanced Storage tool within the Solaris Management Console, open the Hot Spare Pools node and select a hot spare pool. Choose Action⇒Properties to view detailed status information. For more information, see the online help.
Run the following form of the metastat command:
# metastat hot-spare-pool-name |
The following example shows sample output from the metastat command on a hot spare pool.
# metastat hsp001
hsp001: 1 hot spare
c1t3d0s2 Available 16800 blocks
The metahs command can also be used to check the status of a hot spare pool.
For information on the hot spare pool states and the possible actions to take, see Hot Spare Pool States.
