You can use this procedure on any file system except the root (/) file system. Be aware that this type of backup creates a “snapshot” of an active file system. Depending on how the file system is being used when it is write-locked, some files on the backup might not correspond to the actual files on disk.
The following limitations apply to this procedure:
If you use this procedure on a two-way mirror, be aware that data redundancy is lost while one submirror is offline for backup. A multi-way mirror does not have this problem.
There is some overhead on the system when the reattached submirror is resynchronized after the backup is complete.
The high-level steps in this procedure are as follows:
Write-locking the file system (UFS only). Do not lock root (/).
Flushing all data from cache to disk.
Using the metadetach command to take one submirror off of the mirror
Unlocking the file system
Using the fsck command to check the file system on the detached submirror
Backing up the data on the detached submirror
Using the metattach command to place the detached submirror back in the mirror
If you use these procedures regularly, put them into a script for ease of use.
The safer approach to this process is to attach a third or fourth submirror to the mirror, allow it to resynchronize, and use it for the backup. This technique ensures that data redundancy is maintained at all times.
Verify that the mirror is in the “Okay” state.
A mirror that is in the “Maintenance” state should be repaired first.
# metastat mirror |
Flush data and UFS logging data from cache to disk and write-lock the file system.
# /usr/sbin/lockfs -w mount-point |
Only a UFS volume needs to be write-locked. If the volume is set up as a raw device for database management software or some other application, running the lockfs command is not necessary. You might, however, want to run the appropriate vendor-supplied utility to flush any buffers and lock access.
Do not write-lock the root (/) file system. Write-locking the root (/) file system causes the system to hang. If you are backing up your root (/) file system, skip this step.
Detach one submirror from the mirror.
# metadetach mirror submirror |
Is the volume name of the mirror.
Is the volume name of the submirror (volume) being detached.
Reads continue to be made from the other submirror. The mirror is out of sync as soon as the first write is made. This inconsistency is corrected when the detached submirror is reattached in Step 7.
Unlock the file system and allow writes to continue.
# /usr/sbin/lockfs -u mount-point |
You might need to perform necessary unlocking procedures based on vendor-dependent utilities used in Step 2.
Use the fsck command to check the file system on the detached submirror. This step ensures a clean backup occurs.
# fsck /dev/md/rdsk/name |
Perform a backup of the offlined submirror.
Use the ufsdump command or your usual backup utility. For information on performing the backup using the ufsdump command, see Performing Mounted Filesystem Backups Using the ufsdump Command.
To ensure a proper backup, use the raw volume name, such as /dev/md/rdsk/d4. Using the raw volume name access to storage that is greater than 2 Gbytes.
Attach the submirror.
# metattach mirror submirror |
Solaris Volume Manager automatically begins resynchronizing the submirror with the mirror.
This example uses a mirror, d1. The mirror consists of submirrors d2, d3 and d4. The submirror d3 is detached and backed up while submirrors d2 and d4 stay online. The file system on the mirror is /home1.
# metastat d1
d1: Mirror
Submirror 0: d2
State: Okay
Submirror 1: d3
State: Okay
Submirror 1: d4
State: Okay
# /usr/sbin/lockfs -w /home1
# metadetach d1 d3
# /usr/sbin/lockfs -u /home1
# /usr/sbin/fsck /dev/md/rdsk/d3
(Perform backup using /dev/md/rdsk/d3)
# metattach d1 d3
