You can recover a Solaris Volume Manager configuration, even onto a different system from the original system.
If you experience a system failure, you can attach the storage to a different system and recover the complete configuration from the local disk set. For example, assume you have a system with an external disk pack of six disks in it and a Solaris Volume Manager configuration, including at least one state database replica, on some of those disks. If you have a system failure, you can physically move the disk pack to a new system and enable the new system to recognize the configuration. This procedure describes how to move the disks to another system and recover the configuration from a local disk set.
This recovery procedure works only with Solaris 9, and later, Solaris Volume Manager volumes.
Attach the disk or disks that contain the Solaris Volume Manager configuration to a system with no preexisting Solaris Volume Manager configuration.
Do a reconfiguration reboot to ensure that the system recognizes the newly added disks.
# reboot -- -r |
Determine the major/minor number for a slice containing a state database replica on the newly added disks.
Use ls -lL, and note the two numbers between the group name and the date. These numbers are the major/minor numbers for this slice.
# ls -Ll /dev/dsk/c1t9d0s7 brw-r----- 1 root sys 32, 71 Dec 5 10:05 /dev/dsk/c1t9d0s7 |
If necessary, determine the major name corresponding with the major number by looking up the major number in /etc/name_to_major.
# grep " 32" /etc/name_to_major sd 32 |
Update the /kernel/drv/md.conf file with the information that instructs Solaris Volume Manager where to find a valid state database replica on the new disks.
For example, in the line that begins with mddb_bootlist1, replace the sd with the major name you found in step 4. Replace 71 in the example with the minor number you identified in Step 3.
#pragma ident "@(#)md.conf 2.2 04/04/02 SMI" # # Copyright 2004 Sun Microsystems, Inc. All rights reserved. # Use is subject to license terms. # # The parameters nmd and md_nsets are obsolete. The values for these # parameters no longer have any meaning. name="md" parent="pseudo" nmd=128 md_nsets=4; # Begin MDD database info (do not edit) mddb_bootlist1=" |
Reboot to force Solaris Volume Manager to reload your configuration.
You will see messages similar to the following displayed on the console.
volume management starting. Dec 5 10:11:53 host1 metadevadm: Disk movement detected Dec 5 10:11:53 host1 metadevadm: Updating device names in Solaris Volume Manager The system is ready. |
Verify your configuration. Use the metadb command to verify the status of the state database replicas. and metastat command view the status for each volume.
# metadb
flags first blk block count
a m p luo 16 8192 /dev/dsk/c1t9d0s7
a luo 16 8192 /dev/dsk/c1t10d0s7
a luo 16 8192 /dev/dsk/c1t11d0s7
a luo 16 8192 /dev/dsk/c1t12d0s7
a luo 16 8192 /dev/dsk/c1t13d0s7
# metastat
d12: RAID
State: Okay
Interlace: 32 blocks
Original device:
Device Start Block Dbase State Reloc Hot Spare
c1t11d0s3 330 No Okay Yes
c1t12d0s3 330 No Okay Yes
c1t13d0s3 330 No Okay Yes
d20: Soft Partition
Device: d10
State: Okay
Extent Start Block Block count
0 3592 8192
d21: Soft Partition
Device: d10
State: Okay
0 11785 8192
d22: Soft Partition
Device: d10
State: Okay
0 19978 8192
d10: Mirror
Submirror 0: d0
State: Okay
Submirror 1: d1
State: Okay
Pass: 1
Read option: roundrobin (default)
Write option: parallel (default)
d0: Submirror of d10
State: Okay
Stripe 0: (interlace: 32 blocks)
c1t9d0s0 0 No Okay Yes
c1t10d0s0 3591 No Okay Yes
d1: Submirror of d10
State: Okay
c1t9d0s1 0 No Okay Yes
c1t10d0s1 0 No Okay Yes
Device Relocation Information:
Device Reloc Device ID
c1t9d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3487980000U00907AZ
c1t10d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3397070000W0090A8Q
c1t11d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3449660000U00904NZ
c1t12d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS32655400007010H04J
c1t13d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3461190000701001T0
# metadb
# metastat
d12: RAID
State: Okay
Original device:
d20: Soft Partition
Device: d10
State: Okay
0 3592 8192
d21: Soft Partition
Device: d10
State: Okay
0 11785 8192
d22: Soft Partition
Device: d10
State: Okay
0 19978 8192
d10: Mirror
Submirror 0: d0
State: Okay
Submirror 1: d1
State: Okay
Pass: 1
State: Okay
State: Okay
c1t9d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3487980000U00907AZ1
# metastat -p
d12 -r c1t11d0s3 c1t12d0s3 c1t13d0s3 -k -i 32b
d20 -p d10 -o 3592 -b 8192
d21 -p d10 -o 11785 -b 8192
d22 -p d10 -o 19978 -b 8192
d10 -m d0 d1 1
d0 1 2 c1t9d0s0 c1t10d0s0 -i 32b
d1 1 2 c1t9d0s1 c1t10d0s1 -i 32b
The introduction of device ID support for disk sets in Solaris Volume Manager allows you to recover storage from known disk sets and to import the disk set to a different system. The metaimport command allows you to import known disk sets from one system to another system. Both systems must contain existing Solaris Volume Manager configurations that include device ID support. For more information on device ID support, see Asynchronous Shared Storage in Disk Sets. For more information on the metaimport command, see the metaimport(1M) man page.
Become superuser.
Obtain a report on disk sets available for import.
# metaimport -r -v |
Provides a report of the unconfigured disk sets available for import on the system.
Provides detailed information about the state database replica location and status on the disks of unconfigured disk sets available for import on the system.
The following examples show how to print a report on disk sets available for import.
# metaimport -r Drives in regular diskset including disk c1t2d0: c1t2d0 c1t3d0 More info: metaimport -r -v c1t2d0 Import: metaimport -s <newsetname> c1t2d0 Drives in replicated diskset including disk c1t4d0: c1t4d0 c1t5d0 More info: metaimport -r -v c1t4d0 Import: metaimport -s <newsetname> c1t4d0 # metaimport -r -v c1t2d0 Import: metaimport -s <newsetname> c1t2d0 Last update: Mon Dec 29 14:13:35 2003 Device offset length replica flags c1t2d0 16 8192 a u c1t3d0 16 8192 a u c1t8d0 16 8192 a u |
Become superuser.
Verify that a disk set is available for import .
Import an available disk set.
# metaimport -s diskset-name drive-name |
Specifies the name of the disk set being created.
Identifies a disk (c#t#d#) containing a state database replica from the disk set being imported.
Verify that the disk set has been imported.
# metaset -s diskset-name |
The following example shows how to import a disk set.
# metaimport -s red c1t2d0 Drives in diskset including disk c1t2d0: c1t2d0 c1t3d0 c1t8d0 More info: metaimport -r -v c1t2d0# metaset -s red Set name = red, Set number = 1 Host Owner host1 Yes Drive Dbase c1t2d0 Yes c1t3d0 Yes c1t8d0 Yes |
