This section contains links to the tasks that are described in this chapter.
Task |
Description |
For Instructions |
Plan for an IPMP group. |
Lists all ancillary information and required tasks before you can configure an IPMP group. | |
Configure an IPMP interface group with multiple interfaces. |
Configures multiple interfaces as members of an IPMP group. | |
Configure an IPMP group where one of the interfaces is a standby interface. |
Configures one of the interfaces in a multiple interface IPMP group as a standby interface. | |
Configure an IPMP group that consists of a single interface. |
Creates a single interface IPMP group. | |
Display the IPMP group to which a physical interface belongs. |
Explains how to obtain the name of an interface's IPMP group from the output of the ifconfig command. | |
Add an interface to an IPMP group. |
Configures a new interface as a member of an existing IPMP group. | |
Remove an interface from an IPMP group. |
Explains how to remove an interface from an IPMP group. | |
Move an interface from an existing IPMP group to a different group. |
Moves interfaces among IPMP groups. |
How to Move an Interface From One IPMP Group to Another Group |
Change three default settings for the in.mpathd daemon. |
Customizes failure detection time and other parameters of the in.mpathd daemon. |
Task |
Description |
For Instructions |
Remove an interface that has failed. |
Removes a failed interface on a system. |
How to Remove a Physical Interface That Has Failed (DR-Detach) |
Replace an interface that has failed. |
Replaces a failed interface. |
How to Replace a Physical Interface That Has Failed (DR-Attach) |
Recover an interface that was not configured at boot time. |
Recovers a failed interface. |
How to Recover a Physical Interface That Was Not Present at System Boot |
