System Administration Guide: IP Services
Replacing a Failed Physical Interface on Systems That Support Dynamic Reconfiguration
This section contains procedures that relate to administering systems that support dynamic reconfiguration (DR).
Note –
The tasks pertain only to IP layers that are configured by using the ifconfig command. Layers before or after the IP layer, such as ATM or other services, require specific manual steps if the layers are not automated. The steps in the next procedures are used to unconfigure interfaces during predetachment and configure interface after postattachment.
ProcedureHow to Remove a Physical Interface That Has Failed (DR-Detach)
This procedure shows how to remove a physical interface on a system that supports DR. The procedure assumes that the following conditions already exist:
Note –
You can skip Step 2 if the test address is plumbed by using the /etc/hostname.hme0 file.
  1. On the system with the IPMP group configuration, assume the Primary Administrator role or become superuser.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. Display the test address configuration.
    # ifconfig hme0:1
    hme0:1:
    flags=9040842<BROADCAST,RUNNING,MULTICAST,DEPRECATED,IPv4,NOFAILOVER>
    mtu 1500 index 3
    inet 192.168.233.250 netmask ffffff00 broadcast 192.168.233.255
    You need this information to replumb the test address when replacing the physical interface.
  3. Remove the physical interface.
    Refer to the following sources for a complete description of how to remove the physical interface:
    • cfgadm(1M) man page
    • Sun Enterprise 6x00, 5x00, 4x00, and 3x00 Systems Dynamic Reconfiguration User's Guide
    • Sun Enterprise 10000 DR Configuration Guide
ProcedureHow to Replace a Physical Interface That Has Failed (DR-Attach)
This procedure shows how to replace a physical interface on a system that supports DR.
  2. Replace the physical interface.
    Refer to the instructions in the following sources:
    • Sun Enterprise 10000 DR Configuration Guide, or Sun Fire 880 Dynamic Reconfiguration User's Guide
