You can modify any of the address properties described in Table 15–4 by using DHCP Manager or the pntadm -M command. See the pntadm(1M) man page for more information about pntadm -M.
The following figure shows the Address Properties dialog box that you use to modify IP address properties.
The following figure shows the Modify Multiple Addresses dialog box that you use to modify multiple IP addresses.
