System Administration Guide: IP Services
Planning DHCP Configuration of Your Remote Networks
After the initial DHCP configuration, you can place IP addresses in remote networks under DHCP management. However, because the system files are not local to the server, DHCP Manager and dhcpconfig cannot look up information to provide default values, so you must provide the information. Before you try to configure a remote network, be sure you know the following information:
See Adding DHCP Networks for the procedure for adding DHCP networks.
