After you successfully use NIS+ with DHCP, you might encounter errors if changes are made to NIS+. The changes could introduce configuration problems. Use the following explanations of problems and solutions to help you determine the cause of configuration problems.
Problem:Root object does not exist in the NIS+ domain.
Solution:Type the following command:
/usr/lib/nis/nisstat
This command displays statistics for the domain. If the root object does not exist, no statistics are returned.
Set up the NIS+ domain using the System Administration Guide: Naming and Directory Services (NIS+).
Problem:NIS+ is not used for passwd and publickey information.
Solution:Type the following command to view the configuration file for the name service switch:
cat /etc/nsswitch.conf
Check the passwd and publickey entries for the “nisplus” keyword. Refer to the System Administration Guide: Naming and Directory Services (NIS+) for information about configuring the name service switch.
Problem:The domain name is empty.
domainname
If the command lists an empty string, no domain name has been set for the domain. Use local files for your data store, or set up an NIS+ domain for your network. Refer to the System Administration Guide: Naming and Directory Services (NIS+).
Problem:The NIS_COLD_START file does not exist.
Solution:Type the following command on the server system to determine if the file exists:
cat /var/nis/NIS_COLD_START
Use local files for your data store, or create an NIS+ client. Refer to the System Administration Guide: Naming and Directory Services (NIS+).
