A flowacct record contains the attributes described in the following table.
Table 37–4 Attributes of a flowacct Record|
Attribute Name |
Attribute Contents |
Type |
src-addr-address-type |
Source address of the originator. address-type is either v4 for IPv4 or v6 for IPv6, as specified in the IPQoS configuration file. |
Basic |
dest-addr-address-type |
Destination address for the packets. address-type is either v4 for IPv4 or v6 for IPv6, as specified in the IPQoS configuration file. |
Basic |
src-port |
Source port from which the flow originated. |
Basic |
dest-port |
Destination port number to which this flow is bound. |
Basic |
protocol |
Protocol number for the flow. |
Basic |
total-packets |
Number of packets in the flow. |
Basic |
total-bytes |
Number of bytes in the flow. |
Basic |
action-name |
Name of the flowacct action that recorded this flow. |
Basic |
creation-time |
First time that a packet is seen for the flow by flowacct. |
Extended only |
last-seen |
Last time that a packet of the flow was seen. |
Extended only |
diffserv-field |
DSCP in the outgoing packet headers of the flow. |
Extended only |
user |
Either a UNIX User ID or user name, which is obtained from the application. |
Extended only |
projid |
Project ID, which is obtained from the application. |
Extended only |
