The ipgpc classifier supports a variety of selectors that you can use in the filter clause of the IPQoS configuration file. When you define a filter, always use the minimum number of selectors that are needed to successfully retrieve traffic of a particular class. The number of filters you define can impact IPQoS performance.
The next table lists the selectors that are available for ipgpc.
Table 37–1 Filter Selectors for the IPQoS Classifier|
Selector |
Argument |
Information Selected |
saddr |
IP address number. |
Source address. |
daddr |
Destination address. |
sport |
Either a port number or service name, as defined in /etc/services. |
Source port from which a traffic class originated. |
dport |
Destination port to which a traffic class is bound. |
protocol |
Either a protocol number or protocol name, as defined in /etc/protocols. |
Protocol to be used by this traffic class. |
dsfield |
DS codepoint (DSCP) with a value of 0–63. |
DSCP, which defines any forwarding behavior to be applied to the packet. If this parameter is specified, the dsfield_mask parameter must also be specified. |
dsfield_mask |
Bit mask with a value of 0–255. |
Used in tandem with the dsfield selector. dsfield_mask is applied to the dsfield selector to determine which of its bits to match against. |
if_name |
Interface name. |
Interface to be used for either incoming or outgoing traffic of a particular class. |
user |
Number of the UNIX user ID or user name to be selected. If no user ID or user name is on the packet, the default –1 is used. |
User ID that is supplied to an application. |
projid |
Number of the project ID to be selected. |
Project ID that is supplied to an application. |
priority |
Priority number. Lowest priority is 0. |
Priority that is given to packets of this class. Priority is used to order the importance of filters for the same class. |
direction |
Argument can be one of the following: |
Direction of packet flow on the IPQoS machine. |
LOCAL_IN |
Input traffic local to the IPQoS system. |
LOCAL_OUT |
Output traffic local to the IPQoS system. |
FWD_IN |
Input traffic to be forwarded. |
FWD_OUT |
Output traffic to be forwarded. |
precedence |
Precedence value. Highest precedence is 0. |
Precedence is used to order filters with the same priority. |
ip_version |
V4 or V6 |
Addressing scheme that is used by the packets, either IPv4 or IPv6. |
