The Solaris software includes a sample IPsec policy file, ipsecinit.sample. You can use the file as a template to create your own ipsecinit.conf file. The ipsecinit.sample file contains the following examples:
# # For example, # # {rport 23} ipsec {encr_algs des encr_auth_algs md5} # # will protect the telnet traffic originating from the host with ESP using # DES and MD5. Also: # # {raddr 10.5.5.0/24} ipsec {auth_algs any} # # will protect traffic to or from the 10.5.5.0 subnet with AH # using any available algorithm. # # # To do basic filtering, a drop rule may be used. For example: # # {lport 23 dir in} drop {} # {lport 23 dir out} drop {} # will disallow any remote system from telnetting in. # # If you are using IPv6, it may be useful to bypass neighbor discovery # to allow in.iked to work properly with on-link neighbors. To do that, # add the following lines: # # {ulp ipv6-icmp type 133-137 dir both } pass { } # # This will allow neighbor discovery to work normally. |
