System Administration Guide: Network Services
Troubleshooting Procedures and Tips for Mail Services
This section provides some procedures and tips that you can use for troubleshooting problems with mail services.
ProcedureHow to Test the Mail Configuration
To test the changes that you make to your configuration file, follow these instructions.
  1. Restart sendmail on any system that has a revised configuration file.
    # svcadm refresh network/smtp:sendmail
  2. Send test messages from each system.
    # /usr/lib/sendmail -v names </dev/null
    names
    Specify a recipient's email address.
    This command sends a null message to the specified recipient and displays the message activity on your monitor.
  3. Send mail to yourself or other people on the local system by addressing the message to a regular user name.
  4. (Optional) If you are connected to a network, send mail in three directions to someone on another system.
    • From the main system to a client system
    • From a client system to the main system
    • From a client system to another client system
  5. (Optional) If you have a mail gateway, send mail from the mail host to another domain to ensure that the relay mailer and host are configured properly.
  6. (Optional) If you have set up a UUCP connection on your phone line to another host, send mail to someone at that host. Have that person send mail back or call you when the message is received.
  7. Ask someone to send mail to you over the UUCP connection.
    The sendmail program cannot detect whether the message is delivered because the program passes the message to UUCP for delivery.
  8. From different systems, send a message to postmaster and ensure that the message is delivered to your postmaster's mailbox.
How to Check Mail Aliases
The following example shows you how to verify an alias.
% mconnect
connecting to host localhost (127.0.0.1), port 25
connection open
220 your.domain.com ESMTP Sendmail 8.13.6+Sun/8.13.6; Tue, 12 Sep 2004 13:34:13 -0800 (PST)
expn sandy
250 2.1.5 <sandy@phoenix.example.com>
quit
221 2.0.0 your.domain.com closing connection
In this example, the mconnect program opened a connection to a mail server on a local host and enabled you to test that connection. The program runs interactively, so you can issue various diagnostic commands. For a complete description, see the mconnect(1) man page. The entry, expn sandy, provided the expanded address, sandy@phoenix.example.com. Thus, you have verified that mail can be delivered when using the alias sandy.
Remember to avoid loops and inconsistent databases when both local and domain-wide aliases are used. Be especially careful to avoid the creation of alias loops when you move a user from one system to another system.
ProcedureHow to Test the sendmail Rule Sets
To check the input and returns of the sendmail rule sets, follow these instructions.
  1. Change to address test mode.
    # /usr/lib/sendmail -bt
  2. Test a mail address.
    Provide the following numbers and address at the last prompt (>).
    > 3,0 mail-sraddress
    mail-address
    Use the mail address that you are testing.
  3. End the session.
    Press Control-d.
Example 13–6 Address Test Mode Output
The following is an example of the output from the address test mode.
% /usr/lib/sendmail -bt
ADDRESS TEST MODE (ruleset 3 NOT automatically invoked)
Enter <ruleset> <address>
> 3,0 sandy@phoenix
canonify           input: sandy @ phoenix
Canonify2          input: sandy < @ phoenix >
Canonify2        returns: sandy < @ phoenix . example . com . >
canonify         returns: sandy < @ phoenix . example . com . >
parse              input: sandy < @ phoenix . example . com . >
Parse0             input: sandy < @ phoenix . example . com . >
Parse0           returns: sandy < @ phoenix . example . com . >
ParseLocal         input: sandy < @ phoenix . example . com . >
ParseLocal       returns: sandy < @ phoenix . example . com . >
Parse1             input: sandy < @ phoenix . example . com . >
MailerToTriple     input: < mailhost . phoenix . example . com >
MailerToTriple   returns: $# relay $@ mailhost . phoenix . example . com
     $: sandy < @ phoenix . example . com . >
Parse1           returns: $# relay $@ mailhost . phoenix . example . com
parse            returns: $# relay $@ mailhost . phoenix . example . com
How to Verify Connections to Other Systems
The mconnect program opens a connection to a mail server on a host that you specify and enables you to test that connection. The program runs interactively, so you can issue various diagnostic commands. See the mconnect(1) man page for a complete description. The following example verifies that mail to the user name sandy is deliverable.
% mconnect phoenix
connecting to host phoenix (172.31.255.255), port 25
connection open
220 phoenix.example.com ESMTP Sendmail 8.13.1+Sun/8.13.1; Sat, 4 Sep 2004 3:52:56 -0700
expn sandy
quit
If you cannot use mconnect to connect to an SMTP port, check these conditions.
Logging Error Messages
Your mail service logs most error messages by using the syslogd program. By default, the syslogd program sends these messages to a system that is called loghost, which is specified in the /etc/hosts file. You can define loghost to hold all logs for an entire NIS domain. If no loghost is specified, error messages from syslogd are not reported.
The /etc/syslog.conf file controls where the syslogd program forwards messages. You can change the default configuration by editing the /etc/syslog.conf file. You must restart the syslog daemon for any changes to become active. To gather information about mail, you can add the following selections to the file.
The following entry in the /etc/syslog.conf file sends a copy of all critical, informational, and debug messages to /var/log/syslog.
mail.crit;mail.info;mail.debug			/var/log/syslog
Each line in the system log contains a timestamp, the name of the system that generated the line, and a message. The syslog file can log a large amount of information.
The log is arranged in a succession of levels. At the lowest level, only unusual occurrences are logged. At the highest level, even the most mundane and uninteresting events are recorded. As a convention, log levels under 10 are considered “useful.” Log levels that are higher than 10 are usually used for debugging. See Customizing System Message Logging in System Administration Guide: Advanced Administration for information about loghost and the syslogd program.
Other Sources for Mail Diagnostic Information
For other diagnostic information, check the following sources.
