To see a complete list of the contents of the table, follow these instructions.
Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
List all of the entries in alphabetical order by alias.
# aliasadm -1 |
For more information, refer to the aliasadm(1M) man page.
Alternately, you can use the aliasadm command to list individual entries. After you complete the first step in this procedure, type the following:
# aliasadm -m ignatz ignatz: ignatz@saturn # Alias for Iggy Ignatz |
The command matches only the complete alias name, not partial strings. You cannot use metacharacters, such as * and ?, with aliasadm -m.
Also, you can use the aliasadm command to list partial matches. After you complete the first step in this procedure, type the following:
# aliasadm -l | grep partial-string |
Replace partial-string with the desired string for your search.
