System Administration Guide: Network Services
How PPP Configuration File Privileges Work
Solaris PPP 4.0 configuration includes the concept of privileges. Privileges determine the precedence of configuration options, particularly when the same option is invoked in more than one place. An option that is invoked from a privileged source takes precedence over the same option that is invoked from a nonprivileged source.
User Privileges
The only privileged user is superuser (root), with the UID of zero. All other users are not privileged.
File Privileges
The following configuration files are privileged regardless of their ownership:
The file $HOME/.ppprc is owned by the user. Options that are read from $HOME/.ppprc and from the command line are privileged only if the user who is invoking pppd is root.
Arguments that follow the file option are privileged.
Effects of Option Privileges
Some options require the invoking user or source to be privileged in order to work. Options that are invoked on the command line are assigned the privileges of the user who is running the pppd command. These options are not privileged unless the user who is invoking pppd is root.
Option
Status
Explanation
domain
Privileged
Requires privileges for use.
linkname
Privileged
noauth
Privileged
nopam
Privileged
pam
Privileged
plugin
Privileged
privgroup
Privileged
allow-ip addresses
Privileged
name hostname
Privileged
plink
Privileged
noplink
Privileged
plumbed
Privileged
proxyarp
Becomes privileged if noproxyarp has been specified
Cannot be overridden by an unprivileged use.
defaultroute
Privileged if nodefaultroute is set in a privileged file or by a privileged user
Cannot be overridden by an unprivileged user.
disconnect
Privileged if set in a privileged file or by a privileged user
bsdcomp
The nonprivileged user cannot specify a code size that is larger than the privileged user has specified.
deflate
connect
Cannot be overridden by an nonprivileged user.
init
pty
welcome
ttyname
Not privileged if set in a nonprivileged file
Opened with root permissions regardless of who invokes pppd.
Opened with the privileges of the user who invokes pppd.
