The dial-out machine and its remote peer communicate across the PPP link by negotiating and exchanging various instructions. When configuring a dial-out machine, you need to determine what instructions are required by the local and remote modems. Then you create a file that is called a chat script that contains these instructions. This section discusses information about configuring modems and creating chat scripts.
Each remote peer that the dial-out machine needs to connect to probably requires its own chat script.
Chat scripts are typically used only on dial-up links. Leased-line links do not use chat scripts unless the link includes an asynchronous interface that requires startup configuration.
The contents of the chat script are determined by the requirements of your modem model or ISDN TA, and the remote peer. These contents appear as a set of expect-send strings. The dial-out machine and its remote peers exchange the strings as part of the communications initiation process.
An expect string contains characters that the dial-out host machine expects to receive from the remote peer to initiate conversation. A send string contains characters that the dial-out machine sends to the remote peer after receiving the expect string.
Information in the chat script usually includes the following:
Modem commands, often referred to as AT commands, which enable the modem to transmit data over the telephone
Phone number of the target peer
This phone number might be the number that is required by your ISP, or a dial-in server at a corporate site, or an individual machine.
Time-out value, if required
Login sequence that is expected from the remote peer
Login sequence that is sent by the dial-out machine
This section contains chat scripts that you can use as a reference for creating your own chat scripts. The modem manufacturer's guide and information from your ISP and other target hosts contain chat requirements for the modem and your target peers. In addition, numerous PPP web sites have sample chat scripts.
The following is a basic chat script that you can use as a template for creating your own chat scripts.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" AT&F1M0&M5S2=255 SAY "Calling myserver\n" TIMEOUT 60 OK "ATDT1-123-555-1212" ogin: pppuser ssword: \q\U % pppd |
The next table describes the contents of the chat script.
Script Contents |
Explanation |
ABORT BUSY |
Abort transmission if the modem receives this message from the opposite peer. |
ABORT 'NO CARRIER' |
Abort transmission if the modem reports ABORT 'NO CARRIER' when dialing. The cause for this message is usually a dialing or modem negotiation failure. |
REPORT CONNECT |
Gather the CONNECT string from the modem. Print the string. |
TIMEOUT 10 |
Set initial timeout to 10 seconds. The modem's response should be immediate. |
"" AT&F1M0&M5S2=255 |
M0 – Turn off the speaker during connect. &M5 – Make the modem require error control. S2=255 – Disable the TIES “+++” break sequence. |
SAY "Calling myserver\n" |
Display the message Calling myserver on the local machine. |
TIMEOUT 60 |
Reset the timeout to 60 seconds to allow more time for link negotiation. |
OK "ATDT1-123-555-1212" |
Call the remote peer by using the phone number 123-555-1212. |
ogin: pppuser |
Log in to the peer by using UNIX-style login. Supply the user name pppuser. |
ssword: \q\U |
\q – Do not log if debugging with the -v option. \U – Insert in this location the contents of the string that follows -U, which is specified on the command line. Usually, the string contains the password. |
% pppd |
Wait for the % shell prompt, and run the pppd command. |
Solaris PPP 4.0 includes the /etc/ppp/myisp-chat.tmpl, which you can modify for use at your site. /etc/ppp/myisp-chat.tmpl is similar to the basic modem chat script except that the template does not include a login sequence.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" "AT&F1" OK "AT&C1&D2" SAY "Calling myisp\n" TIMEOUT 60 OK "ATDT1-123-555-1212" CONNECT \c |
Script Contents |
Explanation |
ABORT BUSY |
ABORT 'NO CARRIER |
REPORT CONNECT |
TIMEOUT 10 |
"" "AT&F1" |
Reset the modem to factory defaults. |
OK "AT&C1&D2" |
Reset the modem so that, for &C1, DCD from the modem follows carrier. If the remote side hangs up the phone for some reason, then the DCD drops. For &D2, DTR high-to-low transition causes the modem to go “on-hook” or hang up. |
SAY "Calling myisp\n" |
Display the message “Calling myisp” on the local machine. |
TIMEOUT 60 |
CONNECT \c |
Wait for the CONNECT message from the opposite peer's modem. |
Use the next chat script as a template for calling an ISP from a dial-out machine with a U.S. Robotics Courier modem.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" AT&F1M0&M5S2=255 SAY "Calling myisp\n" TIMEOUT 60 OK "ATDT1-123-555-1212" CONNECT \c \r \d\c SAY "Connected; running PPP\n" |
The following table describes the contents of the chat script.
Script Contents |
Explanation |
ABORT BUSY |
REPORT CONNECT |
TIMEOUT 10 |
"" AT&F1M0M0M0M0&M5S2=255 |
Display the message Calling myisp on the local machine. |
TIMEOUT 60 |
CONNECT \c |
\r \d\c |
Wait until the end of the CONNECT message. |
SAY “Connected; running PPP\n” |
Display the informative message Connected; running PPP on the local machine. |
The next chat script is a basic script that is enhanced for calling a remote Solaris peer or other UNIX-type peer. This chat script is used in How to Create the Instructions for Calling a Peer.
SAY "Calling the peer\n"
TIMEOUT 10
ABORT BUSY
ABORT 'NO CARRIER'
ABORT ERROR
REPORT CONNECT
"" AT&F1&M5S2=255
TIMEOUT 60
OK ATDT1-123-555-1234
CONNECT \c
SAY "Connected; logging in.\n"
TIMEOUT 5
ogin:--ogin: pppuser
TIMEOUT 20
ABORT 'ogin incorrect'
ssword: \qmypassword
"% " \c
SAY "Logged in. Starting PPP on peer system.\n"
ABORT 'not found'
"" "exec pppd"
~ \c
The following table explains the parameters of the chat script.
Script Contents |
Explanation |
TIMEOUT 10 |
ABORT BUSY |
ABORT ERROR |
REPORT CONNECT |
"" AT&F1&M5S2=255 |
TIMEOUT 60 |
OK ATDT1-123-555-1234 |
CONNECT \c |
SAY "Connected; logging in.\n" |
Display the informative message Connected; logging in to give the user status. |
TIMEOUT 5 |
Change the timeout to enable quick display of the login prompt. |
ogin:--ogin: pppuser |
Wait for the login prompt. If the prompt is not received, send a RETURN and wait. Then, send the user name pppuser to the peer. The sequence that follows is referred to by most ISPs as the PAP login. However, the PAP login is not related in any way to PAP authentication. |
TIMEOUT 20 |
Change the timeout to 20 seconds to allow for slow password verification. |
ssword: \qmysecrethere |
Wait for the password prompt from the peer. When the prompt is received, send the password \qmysecrethere. The \q prevents the password from being written to the system log files. |
"% " \c |
Wait for a shell prompt from the peer. The chat script uses the C shell. Change this value if the user prefers to log in with a different shell. |
SAY "Logged in. Starting PPP on peer system.\n" |
Display the informative message Logged in. Starting PPP on peer system to give the user status. |
ABORT 'not found' |
Abort the transmission if the shell encounters errors. |
"" "exec pppd" |
Start pppd on the peer. |
~ \c |
Wait for PPP to start on the peer. |
Starting PPP right after the CONNECT \c is often called a PAP login by ISPs, though the PAP login is actually not part of PAP authentication.
The phrase ogin:--ogin: pppuser instructs the modem to send the user name pppuser in response to the login prompt from the dial-in server. pppuser is a special PPP user account name that was created for remote user1 on the dial-in server. For instructions about creating PPP user accounts on a dial-in server, refer to How to Configure Users of the Dial-in Server.
The following chat script is for calling from a dial-out machine with a ZyXEL omni.net. ISDN TA.
TIMEOUT 10
ABORT BUSY
ABORT 'NO CARRIER'
ABORT ERROR
REPORT CONNECT
"" AT&FB40S83.7=1&K44&J3X7S61.3=1S0=0S2=255
OK ATDI18882638234
CONNECT \c
\r \d\c
Refer to the chat(1M) man page for descriptions of options and other detailed information about the chat script. For an explanation of expect-send strings, refer to Chat-Script Field in /etc/uucp/Systems File.
A number of web sites offer sample chat scripts and assistance in creating the chat scripts. For example, see http://ppp.samba.org/ppp/index.html.
You call chat scripts by using the connect option. You can use connect "chat ..." in any PPP configuration file or on the command line.
Chat scripts are not executable, but the program that is invoked by connect must be executable. You might use the chat utility as the program to be invoked by connect. In this instance, if you store the chat script in an external file through the -f option, then your chat script file is not executable.
The chat program that is described in chat(1m) executes the actual chat script. The pppd daemon invokes the chat program whenever pppd encounters the connect "chat ..." option.
You can use any external program, such as Perl or Tcl, to create advanced chat scripts. Solaris PPP 4.0 provides the chat utility as a convenience.
Create the chat script as an ASCII file.
Invoke the chat script in any PPP configuration file by using the following syntax:
connect 'chat -f /etc/ppp/chatfile' |
The -f flag indicates that a file name is to follow. /etc/ppp/chatfile represents the name of the chat file.
Give read permission for the external chat file to the user who runs the pppd command.
The chat program always runs with the user's privileges, even if the connect 'chat ...' option is invoked from a privileged source. Thus, a separate chat file that is read with the -f option must be readable by the invoking user. This privilege can be a security problem if the chat script contains passwords or other sensitive information.
You can place the entire chat script conversation on a single line, similar to the following:
connect 'chat "" "AT&F1" OK ATDT5551212 CONNECT "\c"' |
The complete chat script follows the chat keyword. The script terminates with "\c"'. You use this form in any PPP configuration file or on the command line as an argument to pppd.
If the chat script that is needed for a particular peer is long or complicated, consider creating the script as a separate file. External chat files are easy to maintain and to document. You can add comments to the chat file by preceding the comments with the hash (#) sign.
The procedure How to Create the Instructions for Calling a Peer shows the use of a chat script that is contained in an external file.
You can create a chat file that is an executable script to be run automatically when the dial-up link is initiated. Thus, you can run additional commands during link initiation, such as stty for parity settings, besides the commands that are contained in a traditional chat script.
This executable chat script logs in to an old-style UNIX system that requires 7 bits with even parity. The system then changes to 8 bits with no parity when running PPP.
#!/bin/sh chat "" "AT&F1" OK "ATDT555-1212" CONNECT "\c" stty evenp chat ogin: pppuser ssword: "\q\U" % "exec pppd" stty -evenp |
Use your text editor to create an executable chat program, such as the previous example.
Make the chat program executable.
# chmod +x /etc/ppp/chatprogram |
Invoke the chat program.
connect /etc/ppp/chatprogram |
Chat programs do not have to be located within the /etc/ppp file system. You can store chat programs in any location.
