System Administration Guide: Network Services
Specifying Source and Target
With the rcp command in the C shell, you can specify source (the file or directory you want to copy) and target (the location into which you will copy the file or directory) with either absolute or abbreviated path names.
Absolute Path Names
Abbreviated Path Names
From Local System
mars:/home/jones/myfile.txt
~jones/myfile.txt
After Remote Login
~jones/myfile.txt
Absolute path names identify files or directories that are mounted on a particular system. In the previous example, the first absolute path name identifies a file (myfile.txt) on the mars system. Abbreviated path names identify files or directories relative to a user's home directory, wherever it might reside. In the previous first example, the abbreviated path name identifies the same file, myfile.txt, but uses “~” symbol to indicate the jones home directory:
~ = mars:/home/jones
The examples on the second line demonstrate the user of absolute and abbreviated path names after a remote login. No difference is evident for the abbreviated path name. However, because the remote login operation mounted the jones home directory onto the local system (parallel to the local user's home directory), the absolute path name no longer requires the system name mars. For more information about how a remote login operation mounts another user's home directory, see What Happens After You Log In Remotely.
The following table provides a sample of absolute and abbreviated path names that are recognized by the C shell. The sample uses the following terminology:
Table 29–4 Allowed Syntaxes for Directory and File Names
Logged in to
Syntax
Description
Local system
The local working directory
path/filename
The path and filename in the local working directory
The current user's home directory
~/path/filename
The path and filename beneath the current user's home directory
~user
The home directory of user
~user/path/filename
The path and filename beneath the home directory of user
remote-system:path/filename
The path and filename in the remote working directory
Remote system
The remote working directory
filename
The filename in the remote working directory
path/filename
~/path/filename
The path and filename in the current user's home directory
~user
~/user/path/filename
local-system:path/filename
