 How to Modify Indirect Maps
How to Modify Indirect MapsLog in as a user who has permissions to change the maps.
Using the nistbladm command, make your changes to the indirect map.
See the System Administration Guide: Naming and Directory Services (NIS+). Note that the change becomes effective the next time that the map is used, which is the next time a mount is performed.
