This section describes some of the tasks that are necessary to do the following:
Start and stop the NFS server
Start and stop the automounter
Select a different version of NFS
Starting in the Solaris 10 release, NFS version 4 is the default.
Task |
Description |
For Instructions |
Start the NFS server |
Steps to start the NFS service if it has not been started automatically. | |
Stop the NFS server |
Steps to stop the NFS service. Normally the service should not need to be stopped. | |
Start the automounter |
Steps to start the automounter. This procedure is required when some of the automounter maps are changed. | |
Stop the automounter |
Steps to stop the automounter. This procedure is required when some of the automounter maps are changed. | |
Select a different version of NFS on the server |
Steps to select a different version of NFS on the server. If you choose not to use NFS version 4, use this procedure. | |
Select a different version of NFS on the client |
Steps to select a different version of NFS on the client by modifying the /etc/default/nfs file. If you choose not to use NFS version 4, use this procedure. |
How to Select Different Versions of NFS on a Client by Modifying the /etc/default/nfs File |
Alternate steps to select a different version of NFS on the client by using the command line. If you choose not to use NFS version 4, use this alternate procedure. |
How to Use the Command Line to Select Different Versions of NFS on a Client |
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Enable the NFS service on the server.
Type the following command.
# svcadm enable network/nfs/server |
This command enables the NFS service.
Starting with the Solaris 9 release, the NFS server starts automatically when you boot the system. Additionally, any time after the system has been booted, the NFS service daemons can be automatically enabled by sharing the NFS file system. See How to Set Up Automatic File-System Sharing.
Disable the NFS service on the server.
# svcadm disable network/nfs/server |
Enable the autofs daemon.
Type the following command:
# svcadm enable system/filesystem/autofs |
Disable the autofs daemon.
# svcadm disable system/filesystem/autofs |
Edit the /etc/default/nfs file.
For example, if you want the server to provide only version 3, set the values for both NFS_SERVER_VERSMAX and NFS_SERVER_VERSMIN to 3. For a list of keywords and their values, refer to Keywords for the /etc/default/nfs File.
NFS_SERVER_VERSMAX=value NFS_SERVER_VERSMIN=value |
Provide the version number.
By default, these lines are commented. Remember to remove the pound (#) sign, also.
Change SMF parameters to set the NFS version numbers.
For example, if you want the server to provide only version 3, set the values for both the server_vermax and server_versmin to 3 as shown below:
# sharectl set -p server_vermax=3 nfs # sharectl set -p server_vermin=3 nfs |
(Optional) If you want to disable server delegation, include this line in the /etc/default/nfs file.
NFS_SERVER_DELEGATION=off |
In NFS version 4, server delegation is enabled by default. For more information, see Delegation in NFS Version 4.
(Optional) If you want to set a common domain for clients and servers, include this line in the /etc/default/nfs file.
NFSMAPID_DOMAIN=my.comany.com |
Provide the common domain
For more information, refer to nfsmapid Daemon.
Check if the NFS service is running on the server.
# svcs network/nfs/server |
This command reports whether the NFS server service is online or disabled.
(Optional) If necessary, disable the NFS service.
If you discovered from the previous step that the NFS service is online, type the following command to disable the service.
If you need to configure your NFS service, refer to How to Set Up Automatic File-System Sharing.
Enable the NFS service.
Type the following command to enable the service.
The following procedure shows you how to control which version of NFS is used on the client by modifying the /etc/default/nfs file. If you prefer to use the command line, refer to How to Use the Command Line to Select Different Versions of NFS on a Client.
For example, if you want only version 3 on the client, set the values for both NFS_CLIENT_VERSMAX and NFS_CLIENT_VERSMIN to 3. For a list of keywords and their values, refer to Keywords for the /etc/default/nfs File.
NFS_CLIENT_VERSMAX=value NFS_CLIENT_VERSMIN=value |
Mount NFS on the client.
# mount server-name:/share-point /local-dir |
Provide the name of the server.
Provide the path of the remote directory to be shared.
Provide the path of the local mount point.
The following procedure shows you how to use the command line to control which version of NFS is used on a client for a particular mount. If you prefer to modify the /etc/default/nfs file, see How to Select Different Versions of NFS on a Client by Modifying the /etc/default/nfs File.
Mount the desired version of NFS on the client.
# mount -o vers=value server-name:/share-point /local-dir |
This command uses the NFS protocol to mount the remote directory and overrides the client settings in the /etc/default/nfs file.
