System Administration Guide: Network Services
Setting Up FTP Server Logins
To access an FTP server, you must first log in. The FTP server supports three types of user login accounts for real, guests, and anonymous users.
ProcedureHow to Set Up Real FTP Users
To enable access for real users to the FTP server, follow these instructions:
  1. Verify that the user has an account that is set up with a user name and password that can be used to establish a terminal session.
    For more information, see Chapter 4, Managing User Accounts and Groups (Overview), in System Administration Guide: Basic Administration.
  2. Confirm that the real user is a member of a class in the ftpaccess file.
    For information on the user classes that are defined in the ftpaccess file, see How to Define FTP Server Classes.
  3. Verify that the user's login shell is listed in the /etc/shells file.
ProcedureHow to Set Up Guest FTP Users
The ftpconfig script is used to copy all necessary system files to the home directory. When the guest user and the guest's home directory already exist, the ftpconfig script updates the area with the current system files.
For more information, see ftpconfig(1M)
Note –
Unlike the user name (anonymous or ftp) that is set for anonymous users, user names for FTP guests are not fixed. Any name that would work as a real user name can be selected.
To enable access by a guest user to the FTP server, do the following:
  1. Use the useradd script to create a guest user account with a login shell of /bin/true and a home directory of /root-dir/./home-dir.
    For more information, see useradd(1M) and Chapter 4, Managing User Accounts and Groups (Overview), in System Administration Guide: Basic Administration.
    Note –
    In this procedure, /home/guests/./guest1 is used as the home directory name for a user who is called guest1.
    # /usr/sbin/useradd -m -c "Guest FTP" -d \
      /home/guests/./guest1 -s /bin/true guest1
  2. Assign a password to the guest account.
  3. Add a guestuser entry to the ftpaccess file.
    guestuser guest1
    Note –
    You can also use the guestgroup capability in the ftpaccess file to specify guest users. The guest-root capability in ftpaccess eliminates the need for the /./ in the guest user's home directory path.
  4. Confirm that the guest user is a member of a class in the ftpaccess file. See How to Define FTP Server Classes for further information.
  5. Use the ftpconfig script to create the required files in the chroot area.
    /usr/sbin/ftpconfig -d /home/guests
  6. Confirm that /bin/true is listed in the /etc/shells file. See How to Create the /etc/shells file.
Example 28–6 Setting Up a Guest FTP Server
In this example, the FTP area is set up in the /home/guests directory.
# /usr/sbin/ftpconfig -d /home/guests
Updating directory /home/guests
ProcedureHow to Set Up Anonymous FTP Users
The ftpconfig script creates the anonymous user account and populates the home directory with the required files.
For more information, see ftpconfig(1M).
To enable access by an anonymous user to the FTP server, follow these instructions:
  1. Use the ftpconfig script to create the anonymous user account.
    /usr/sbin/ftpconfig anonymous-ftp-directory
  2. Confirm that the anonymous user is assigned to a class in the ftpaccess file.
Example 28–7 Setting Up Anonymous FTP Users
In this example, the FTP area is set up in the /home/ftp directory.
# /usr/sbin/ftpconfig /home/ftp
Creating user ftp
Updating directory /home/ftp
ProcedureHow to Create the /etc/shells file
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Create the /etc/shells file.
  3. Edit /etc/shells. Add the full path to each shell on a single line.
Example 28–8 Creating the /etc/shells file
The following is an example of an /etc/shells file with a /bin/true listed for FTP guest users:
/sbin/sh
/bin/csh
/bin/jsh
/bin/ksh
/bin/remsh
/bin/rksh
/bin/rsh
/bin/sh
/usr/bin/csh
/usr/bin/ksh
/usr/bin/bash
/usr/bin/tcsh
/usr/bin/zsh
/bin/true
