The FTP server can be started in one of three ways:
As a standalone server run in the background
As a standalone server run in the foreground from the inittab file
A standalone server always has the quickest possible response time, and is intended for large servers that are dedicated to providing FTP service. The standalone server provides low connection latency for dedicated servers because the standalone system never has to be restarted. The standalone server is always running, even during off-peak hours, waiting indefinitely for connections.
By default, the SMF service is configured to start the FTP server using the nowait mode. If the site handles many connections, the FTP server can also be run in standalone mode. See the in.ftpd(1M) man page for information on additional command-line options.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Verify the wait property for the FTP server.
The line reporting that wait=FALSE indicates that the server is started in nowait mode.
# inetadm -l network/ftp
SCOPE NAME=VALUE
name="ftp"
endpoint_type="stream"
proto="tcp6"
isrpc=FALSE
wait=FALSE
exec="/usr/sbin/in.ftpd -a"
user="root"
default bind_addr=""
default bind_fail_max=-1
default bind_fail_interval=-1
default max_con_rate=-1
default max_copies=-1
default con_rate_offline=-1
default failrate_cnt=40
default failrate_interval=60
default inherit_env=TRUE
default tcp_trace=FALSE
default tcp_wrappers=FALSE
Start the FTP server.
# svcadm enable network/ftp |
Disable the FTP server.
# svcadm disable network/ftp |
Start the standalone FTP server.
# /usr/sbin/in.ftpd -a -S |
Add the line to an FTP server startup script. See Using Run Control Scripts in System Administration Guide: Basic Administration for information on creating a system startup script.
Add an entry to the inittab file to start the service.
The new entry in /etc/inittab should look something like the following:
ftpd:3:respawn:/usr/sbin/in.ftpd -a -s |
Tell init to re-examine /etc/inittab.
This command should start the FTP service.
# init q |
