Use the Sun Java System Directory Server idsconfig command to set up VLVs if the following conditions apply:
You are using the Sun Java System Directory Server.
You are mapping standard maps to RFC 2307 LDAP entries.
VLVs are domain specific, so each time idsconfig is run, VLVs are created for one NIS domain. Therefore, during the NIS–to–LDAP transition, you must run idsconfig once for each nisLDAPdomainContext attribute included in the NISLDAPmapping file.
