The master files that are used by the system files checks are generated when you first execute ASET. The master files are also generated when you run ASET after changing the security level.
The following environment variables define the files that are checked by this task:
CKLISTPATH_LOW
CKLISTPATH_MED
CKLISTPATH_HIGH
