System Administration Guide: Security Services
Modifying the Environment File (asetenv)
The /usr/aset/asetenv file has two main sections:
You can alter the user-configurable parameters section. However, the settings in the internal environment variables section are for internal use only. These settings should not be modified.
You can edit the entries in the user-configurable section to do the following:
