System Administration Guide: Security Services
audit_event File
The /etc/security/audit_event file contains the default audit event-class mappings. You can edit this file to change the class mappings. When you change class mappings, you must reboot the system or run the auditconfig -conf command to read the changed mappings into the kernel. For more information, see the audit_event(4) man page.
