System Administration Guide: Security Services
ProcedureHow to Audit FTP and SFTP File Transfers
The FTP service creates logs of its file transfers. The SFTP service, which runs under the SSH protocol, can be audited by Solaris auditing. Logins to both services can be audited by Solaris auditing.
  1. To log commands and file transfers of the FTP service, see the ftpaccess(4) man page.
    For the available logging options, read the “Logging Capabilities” section. In particular, the log commands and log transfers options might provide useful logs.
  2. To log sftp file transfers, perform one or both of the following:
    • Audit file-reads.
      File transfers over an SSH connection use the sftp command. These transfers can be recorded by using the +fr audit flag. To audit failed sftp file transfers, audit the -fr audit flag.
      The following output is from a successful sftp session:
      header,138,2,open(2) - read,,ma2,2009-08-25 14:48:58.770 -07:00
      path,/home/jdoe/vpn_connect
      attribute,100644,jdoe,staff,391,437,0
      subject,jdoe,jdoe,staff,jdoe,staff,4444,120289379,8457 65558 ma1
      return,success,6
    • Use the verbose option to the sftp command.
      The -v option can be repeated up to three times.
      # sftp -vvv [ other options ] hostname
  3. To record access to the FTP and SFTP services, audit the lo class.
    As the following output indicates, logging in to and out of the ftpd daemon generates audit records.
    % bsmrecord -c lo | more
    in.ftpd
      program     /usr/sbin/in.ftpd    See ftp access
      event ID    6165                 AUE_ftpd
      class       lo                   (0x00001000)
          header
          subject
          [text]                       error message
          return
    in.ftpd
      program     /usr/sbin/in.ftpd    See ftp logout
      event ID    6171                 AUE_ftpd_logout
          header
          subject
          return
    The SSH login records all accesses to the sftp command.
    /usr/lib/ssh/sshd
      program     /usr/lib/ssh/sshd    See login - ssh
      event ID    6172                 AUE_ssh
          header
          subject
          return
