System Administration Guide: Security Services
ProcedureHow to Change Which Devices Can Be Allocated
  1. Assume a role that includes the Device Security rights profile, or become superuser.
    The Primary Administrator role includes the Device Security rights profile. You can also assign the Device Security rights profile to a role that you create. To create the role and assign the role to a user, see Example 9–3.
  2. Specify if authorization is required, or specify the solaris.device.allocate authorization.
    Change the fifth field in the device entry in the device_allocate file.
    audio;audio;reserved;reserved;solaris.device.allocate;/etc/security/lib/audio_clean
    fd0;fd;reserved;reserved;solaris.device.allocate;/etc/security/lib/fd_clean
    sr0;sr;reserved;reserved;solaris.device.allocate;/etc/security/lib/sr_clean
    where solaris.device.allocate indicates that a user must have the solaris.device.allocate authorization to use the device.
Example 4–4 Permitting Any User to Allocate a Device
In the following example, any user on the system can allocate any device. The fifth field in every device entry in the device_allocate file has been changed to an at sign (@).
$ whoami
devicesec
$ vi /etc/security/device_allocate
audio;audio;reserved;reserved;@;/etc/security/lib/audio_clean
fd0;fd;reserved;reserved;@;/etc/security/lib/fd_clean
sr0;sr;reserved;reserved;@;/etc/security/lib/sr_clean
Example 4–5 Preventing Some Peripheral Devices From Being Used
In the following example, the audio device cannot be used. The fifth field in the audio device entry in the device_allocate file has been changed to an asterisk (*).
$ whoami
devicesec
audio;audio;reserved;reserved;*;/etc/security/lib/audio_clean
fd0;fd;reserved;reserved;solaris device.allocate;/etc/security/lib/fd_clean
sr0;sr;reserved;reserved;solaris device.allocate;/etc/security/lib/sr_clean
Example 4–6 Preventing All Peripheral Devices From Being Used
In the following example, no peripheral device can be used. The fifth field in every device entry in the device_allocate file has been changed to an asterisk (*).
$ whoami
devicesec
fd0;fd;reserved;reserved;*;/etc/security/lib/fd_clean
sr0;sr;reserved;reserved;*;/etc/security/lib/sr_clean
