System Administration Guide: Security Services
Writing New Device-Clean Scripts
If you add more allocatable devices to the system, you might need to create your own device-clean scripts. The deallocate command passes a parameter to the device-clean scripts. The parameter, which is shown here, is a string that contains the device name. For more information, see the device_allocate(4) man page.
clean-script -[I|i|f|S] device-name
Device-clean scripts must return “0” for success and greater than “0” for failure. The options -I, -f, and -S determine the running mode of the script:
-I
Is needed during system boot only. All output must go to the system console. Failure or inability to forcibly eject the media must put the device in the allocate error state.
-i
Similar to the -I option, except that output is suppressed.
-f
Is for forced cleanup. The option is interactive and assumes that the user is available to respond to prompts. A script with this option must attempt to complete the cleanup if one part of the cleanup fails.
-S
Is for standard cleanup. The option is interactive and assumes that the user is available to respond to prompts.
