You can create a file in PKCS #12 format to export private keys and their associated X.509 certificate to other systems. Access to the file is protected by a password.
Find the certificate to export.
% pktool list
Found number certificates.
1. (X.509 certificate)
Label: label-name
ID: Fingerprint that binds certificate to private key
Subject: subject-DN
Issuer: distinguished-name
Serial: hex-serial-number
2. ...
Export the keys and certificate.
Use the keystore and label from the pktool list command. Provide a file name for the export file. When the name contains a space, surround the name with double quotes.
% pktool export keystore=keystore outfile=outfile-name label=label-name |
Protect the export file with a password.
At the prompt, type the current password for the keystore. At this point, you create a password for the export file. The receiver must provide this password when importing the file.
Enter pin for Sun Software PKCS#11 softtoken: Type PIN for token Enter password to use for accessing the PKCS12 file:Create PKCS #12 password |
Send the password separately from the export file. Best practice suggests that you provide the password out of band, such as during a telephone call.
In the following example, a user exports the private keys with their associated X.509 certificate into a standard PKCS #12 file. This file can be imported into other keystores. The PKCS #11 password protects the source keystore. The PKCS #12 password is used to protect private data in the PKCS #12 file. This password is required to import the file.
% pktool list
Found 1 certificates.
Label: My Cert
Subject: C=US, O=My Company, OU=Security Engineering Group, CN=MyCA
Issuer: C=US, O=My Company, OU=Security Engineering Group, CN=MyCA
Serial: 0x01
% pktool export keystore=pkcs11 outfile=mydata.p12 label="My Cert" Enter pin for Sun Software PKCS#11 softtoken: Type PIN for token Enter password to use for accessing the PKCS12 file:Create PKCS #12 password |
The user then telephones the recipient and provides the PKCS #12 password.
