Some applications require a symmetric key for encryption and decryption of communications. In this procedure, you create a symmetric key and store it.
If your site has a random number generator, you can use the generator to create a random number for the key. This procedure does not use your site's random number generator.
You can instead use the dd command with the Solaris /dev/urandom device as input. The dd command does not store the key. For the procedure, see How to Generate a Symmetric Key by Using the dd Command.
(Optional) If you plan to use a keystore, create it.
To create and initialize a PKCS #11 keystore, see How to Generate a Passphrase by Using the pktool setpin Command.
To create and initialize an NSS database, see Example 15–5.
Generate a random number for use as a symmetric key.
Use one of the following methods.
Generate a key and store it in a file.
The advantage of a file-stored key is that you can extract the key from this file for use in an application's key file, such as the /etc/inet/secret/ipseckeys file or IPsec.
% pktool genkey keystore=file outkey=key-fn \ [keytype=specific-symmetric-algorithm] [keylen=size-in-bits] \ [dir=directory] [print=n] |
The value file specifies the file type of storage location for the key.
Is the filename when keystore=file.
For a particular algorithm, specify aes, arcfour, des, or 3des.
Is the length of the key in bits. The number must be divisible by 8. Do not specify for des or 3des.
Is the directory path to key-fn. By default, directory is the current directory.
Prints the key to the terminal window. By default, the value of print is n.
Generate a key and store it in a PKCS #11 keystore.
The advantage of the PKCS #11 keystore is that you can retrieve the key by its label. This method is useful for keys that encrypt and decrypt files. You must complete Step 1 before using this method.
% pktool genkey label=key-label \ [keytype=specific-symmetric-algorithm] [keylen=size-in-bits] \ [token=token] [sensitive=n] [extractable=y] [print=n] |
Is a user-specified label for the key. The key can be retrieved from the keystore by its label.
Is the token name. By default, the token is Sun Software PKCS#11 softtoken.
Specifies the sensitivity of the key. When the value is y, the key cannot be printed by using the print=y argument. By default, the value of sensitive is n.
Specifies that the key can be extracted from the keystore. Specify n to prevent the key from being extracted.
Generate a key and store it in an NSS keystore.
% pktool keystore=nss genkey label=key-label \ [keytype=[keytype=specific-symmetric-algorithm] [keylen=size-in-bits] [token=token] \ [dir=directory-path] [prefix=database-prefix] |
The value nss specifies the NSS type of storage location for the key.
Is the token name. By default, the token is the NSS internal token.
Is the directory path to the NSS database. By default, directory is the current directory.
Is the prefix to the NSS database. The default is no prefix.
(Optional) Verify that the key exists.
Use one of the following commands, depending on where you stored the key.
In the following example, a secret key for the DES algorithm is created. The key is stored in a local file for later decryption. The command protects the file with 400 permissions. When the key is created, the print=y option displays the generated key in the terminal window.
DES mechanisms use a 64-bit key. The user who owns the keyfile retrieves the key by using the od command.
% pktool genkey keystore=file outkey=64bit.file1 keytype=des print=y
Key Value ="a3237b2c0a8ff9b3"
% od -x 64bit.file1
0000000 a323 7b2c 0a8f f9b3
