System Administration Guide: Security Services
ProcedureHow to Add a Software Provider
  1. Assume the Primary Administrator role, or become superuser.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. List the software providers that are available to the system.
    % cryptoadm list
    user-level providers:
        /usr/lib/security/$ISA/pkcs11_kernel.so
        /usr/lib/security/$ISA/pkcs11_softtoken.so
    kernel software providers:
        des
        aes
        blowfish
        arcfour
        sha1
        md5
        rsa
    kernel hardware providers:
        ncp/0
  3. Add the provider's package by using the pkgadd command.
    # pkgadd -d /path/to/package pkginst
    The package must include software that has been signed by a certificate from Sun. To request a certificate from Sun and to sign a provider, see Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
    The package should have scripts that notify the cryptographic framework that another provider with a set of mechanisms is available. For information about the packaging requirements, see Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
  4. Refresh the providers.
    You need to refresh providers if you added a software provider, or if you added hardware and specified policy for the hardware.
    # svcadm refresh svc:/system/cryptosvc
  5. Locate the new provider on the list.
    In this case, a new kernel software provider was installed.
    # cryptoadm list
        des
        aes
        blowfish
        arcfour
        sha1
        md5
        rsa
        swrand
        ecc <-- added provider
Example 14–17 Adding a User-Level Software Provider
In the following example, a signed PKCS #11 library is installed.
# pkgadd -d /cdrom/cdrom0/SolarisNew
Answer the prompts
# svcadm refresh system/cryptosvc
# cryptoadm list
    /opt/SUNWconn/lib/$ISA/libpkcs11.so.1 <-- added provider
Developers who are testing a library with the cryptographic framework can install the library manually.
# cryptoadm install provider=/opt/SUNWconn/lib/\$ISA/libpkcs11.so.1
For information on getting your provider signed, see Binary Signatures for Third-Party Software.
