This section describes how to generate symmetric keys, how to create checksums for file integrity, and how to protect files from eavesdropping. The commands in this section can be run by regular users. Developers can write scripts that use these commands.
A key is needed to encrypt files and to generate the MAC of a file. The key should be derived from a random pool of numbers.
If your site has a random number generator, use the generator. Otherwise, you can use the dd command with the Solaris /dev/urandom device as input. For more information, see the dd(1M) man page.
Determine the key length that your algorithm requires.
List the available algorithms.
% encrypt -l Algorithm Keysize: Min Max (bits) ------------------------------------------ aes 128 128 arcfour 8 128 des 64 64 3des 192 192 % mac -l Algorithm Keysize: Min Max (bits) ------------------------------------------ des_mac 64 64 sha1_hmac 8 512 md5_hmac 8 512 sha256_hmac 8 512 sha384_hmac 8 1024 sha512_hmac 8 1024 |
Determine the key length in bytes to pass to the dd command.
Divide the minimum and maximum key sizes by 8. When the minimum and maximum key sizes are different, intermediate key sizes are possible. For example, the value 8, 16, or 64 can be passed to the dd command for the sha1_hmac and md5_hmac functions.
Generate the symmetric key.
% dd if=/dev/urandom of=keyfile bs=n count=n |
Is the input file. For a random key, use the /dev/urandom file.
Is the output file that holds the generated key.
Is the key size in bytes. For the length in bytes, divide the key length in bits by 8.
Is the count of the input blocks. The number for n should be 1.
Store your key in a protected directory.
The key file should not be readable by anyone but the user.
% chmod 400 keyfile |
In the following example, a secret key for the AES algorithm is created. The key is also stored for later decryption. AES mechanisms use a 128-bit key. The key is expressed as 16 bytes in the dd command.
% ls -al ~/keyf drwx------ 2 jdoe staff 512 May 3 11:32 ./ % dd if=/dev/urandom of=$HOME/keyf/05.07.aes16 bs=16 count=1 % chmod 400 ~/keyf/05.07.aes16 |
In the following example, a secret key for the DES algorithm is created. The key is also stored for later decryption. DES mechanisms use a 64-bit key. The key is expressed as 8 bytes in the dd command.
% dd if=/dev/urandom of=$HOME/keyf/05.07.des8 bs=8 count=1 % chmod 400 ~/keyf/05.07.des8 |
In the following example, a secret key for the 3DES algorithm is created. The key is also stored for later decryption. 3DES mechanisms use a 192-bit key. The key is expressed as 24 bytes in the dd command.
% dd if=/dev/urandom of=$HOME/keyf/05.07.3des.24 bs=24 count=1 % chmod 400 ~/keyf/05.07.3des.24 |
In the following example, a secret key for the MD5 algorithm is created. The key is also stored for later decryption. The key is expressed as 64 bytes in the dd command.
% dd if=/dev/urandom of=$HOME/keyf/05.07.mack64 bs=64 count=1 % chmod 400 ~/keyf/05.07.mack64 |
Some applications require a symmetric key for encryption and decryption of communications. In this procedure, you create a symmetric key and store it.
If your site has a random number generator, you can use the generator to create a random number for the key. This procedure does not use your site's random number generator.
You can instead use the dd command with the Solaris /dev/urandom device as input. The dd command does not store the key. For the procedure, see How to Generate a Symmetric Key by Using the dd Command.
(Optional) If you plan to use a keystore, create it.
To create and initialize a PKCS #11 keystore, see How to Generate a Passphrase by Using the pktool setpin Command.
To create and initialize an NSS database, see Example 15–5.
Generate a random number for use as a symmetric key.
Use one of the following methods.
Generate a key and store it in a file.
The advantage of a file-stored key is that you can extract the key from this file for use in an application's key file, such as the /etc/inet/secret/ipseckeys file or IPsec.
% pktool genkey keystore=file outkey=key-fn \ [keytype=specific-symmetric-algorithm] [keylen=size-in-bits] \ [dir=directory] [print=n] |
The value file specifies the file type of storage location for the key.
Is the filename when keystore=file.
For a particular algorithm, specify aes, arcfour, des, or 3des.
Is the length of the key in bits. The number must be divisible by 8. Do not specify for des or 3des.
Is the directory path to key-fn. By default, directory is the current directory.
Prints the key to the terminal window. By default, the value of print is n.
Generate a key and store it in a PKCS #11 keystore.
The advantage of the PKCS #11 keystore is that you can retrieve the key by its label. This method is useful for keys that encrypt and decrypt files. You must complete Step 1 before using this method.
% pktool genkey label=key-label \ [keytype=specific-symmetric-algorithm] [keylen=size-in-bits] \ [token=token] [sensitive=n] [extractable=y] [print=n] |
Is a user-specified label for the key. The key can be retrieved from the keystore by its label.
Is the token name. By default, the token is Sun Software PKCS#11 softtoken.
Specifies the sensitivity of the key. When the value is y, the key cannot be printed by using the print=y argument. By default, the value of sensitive is n.
Specifies that the key can be extracted from the keystore. Specify n to prevent the key from being extracted.
Generate a key and store it in an NSS keystore.
% pktool keystore=nss genkey label=key-label \ [keytype=[keytype=specific-symmetric-algorithm] [keylen=size-in-bits] [token=token] \ [dir=directory-path] [prefix=database-prefix] |
The value nss specifies the NSS type of storage location for the key.
Is the token name. By default, the token is the NSS internal token.
Is the directory path to the NSS database. By default, directory is the current directory.
Is the prefix to the NSS database. The default is no prefix.
(Optional) Verify that the key exists.
Use one of the following commands, depending on where you stored the key.
In the following example, a secret key for the DES algorithm is created. The key is stored in a local file for later decryption. The command protects the file with 400 permissions. When the key is created, the print=y option displays the generated key in the terminal window.
DES mechanisms use a 64-bit key. The user who owns the keyfile retrieves the key by using the od command.
% pktool genkey keystore=file outkey=64bit.file1 keytype=des print=y Key Value ="a3237b2c0a8ff9b3" % od -x 64bit.file1 0000000 a323 7b2c 0a8f f9b3 |
When you compute a digest of a file, you can check to see that the file has not been tampered with by comparing digest outputs. A digest does not alter the original file.
List the available digest algorithms.
% digest -l md5 sha1 sha256 sha384 sha512 |
Compute the digest of the file and save the digest listing.
Provide an algorithm with the digest command.
% digest -v -a algorithm input-file > digest-listing |
Displays the output in the following format:
algorithm (input-file) = digest |
Is the algorithm to use to compute a digest of the file. Type the algorithm as the algorithm appears in the output of Step 1.
Is the input file for the digest command.
Is the output file for the digest command.
In the following example, the digest command uses the MD5 mechanism to compute a digest for an email attachment.
% digest -v -a md5 email.attach >> $HOME/digest.emails.05.07 % cat ~/digest.emails.05.07 md5 (email.attach) = 85c0a53d1a5cc71ea34d9ee7b1b28b01 |
When the -v option is not used, the digest is saved with no accompanying information:
% digest -a md5 email.attach >> $HOME/digest.emails.05.07 % cat ~/digest.emails.05.07 85c0a53d1a5cc71ea34d9ee7b1b28b01 |
In the following example, the digest command uses the SHA1 mechanism to provide a directory listing. The results are placed in a file.
% digest -v -a sha1 docs/* > $HOME/digest.docs.legal.05.07 % more ~/digest.docs.legal.05.07 sha1 (docs/legal1) = 1df50e8ad219e34f0b911e097b7b588e31f9b435 sha1 (docs/legal2) = 68efa5a636291bde8f33e046eb33508c94842c38 sha1 (docs/legal3) = 085d991238d61bd0cfa2946c183be8e32cccf6c9 sha1 (docs/legal4) = f3085eae7e2c8d008816564fdf28027d10e1d983 |
A message authentication code, or MAC, computes a digest for the file and uses a secret key to further protect the digest. A MAC does not alter the original file.
List the available mechanisms.
% mac -l Algorithm Keysize: Min Max ----------------------------------- des_mac 64 64 sha1_hmac 8 512 md5_hmac 8 512 sha256_hmac 8 512 sha384_hmac 8 1024 sha512_hmac 8 1024 |
Generate a symmetric key of the appropriate length.
You have two options. You can provide a passphrase from which a key will be generated. Or you can provide a key.
If you provide a passphrase, you must store or remember the passphrase. If you store the passphrase online, the passphrase file should be readable only by you.
If you provide a key, it must be the correct size for the mechanism. For the procedure, see How to Generate a Symmetric Key by Using the dd Command.
Provide a key and use a symmetric key algorithm with the mac command.
% mac -v -a algorithm [ -k keyfile ] input-file |
algorithm (input-file) = mac |
Is the algorithm to use to compute the MAC. Type the algorithm as the algorithm appears in the output of the mac -l command.
Is the file that contains a key of algorithm-specified length.
Is the input file for the MAC.
In the following example, the email attachment is authenticated with the DES_MAC mechanism and a key that is derived from a passphrase. The MAC listing is saved to a file. If the passphrase is stored in a file, the file should not be readable by anyone but the user.
% mac -v -a des_mac email.attach Enter passphrase: <Type passphrase> des_mac (email.attach) = dd27870a % echo "des_mac (email.attach) = dd27870a" >> ~/desmac.daily.05.07 |
In the following example, the email attachment is authenticated with the MD5_HMAC mechanism and a secret key. The MAC listing is saved to a file.
% mac -v -a md5_hmac -k $HOME/keyf/05.07.mack64 email.attach md5_hmac (email.attach) = 02df6eb6c123ff25d78877eb1d55710c % echo "md5_hmac (email.attach) = 02df6eb6c123ff25d78877eb1d55710c" \ >> ~/mac.daily.05.07 |
In the following example, the directory manifest is authenticated with the SHA1_HMAC mechanism and a secret key. The results are placed in a file.
% mac -v -a sha1_hmac \ -k $HOME/keyf/05.07.mack64 docs/* > $HOME/mac.docs.legal.05.07 % more ~/mac.docs.legal.05.07 sha1_hmac (docs/legal1) = 9b31536d3b3c0c6b25d653418db8e765e17fe07a sha1_hmac (docs/legal2) = 865af61a3002f8a457462a428cdb1a88c1b51ff5 sha1_hmac (docs/legal3) = 076c944cb2528536c9aebd3b9fbe367e07b61dc7 sha1_hmac (docs/legal4) = 7aede27602ef6e4454748cbd3821e0152e45beb4 |
When you encrypt a file, the original file is not removed or changed. The output file is encrypted.
For solutions to common errors from the encrypt command, see the section that follows the examples.
Create a symmetric key of the appropriate length.
Provide a key and use a symmetric key algorithm with the encrypt command.
% encrypt -a algorithm [ -k keyfile ] -i input-file -o output-file |
Is the algorithm to use to encrypt the file. Type the algorithm as the algorithm appears in the output of the encrypt -l command.
Is the file that contains a key of algorithm-specified length. The key length for each algorithm is listed, in bits, in the output of the encrypt -l command.
Is the input file that you want to encrypt. This file is left unchanged by the command.
Is the output file that is the encrypted form of the input file.
In the following example, a file is encrypted with the AES algorithm. The key is generated from the passphrase. If the passphrase is stored in a file, the file should not be readable by anyone but the user.
% encrypt -a aes -i ticket.to.ride -o ~/enc/e.ticket.to.ride Enter passphrase: <Type passphrase> Re-enter passphrase: Type passphrase again |
The input file, ticket.to.ride, still exists in its original form.
To decrypt the output file, the user uses the same passphrase and encryption mechanism that encrypted the file.
% decrypt -a aes -i ~/enc/e.ticket.to.ride -o ~/d.ticket.to.ride Enter passphrase: <Type passphrase> |
In the following example, a file is encrypted with the AES algorithm. AES mechanisms use a key of 128 bits, or 16 bytes.
% encrypt -a aes -k ~/keyf/05.07.aes16 \ -i ticket.to.ride -o ~/enc/e.ticket.to.ride |
To decrypt the output file, the user uses the same key and encryption mechanism that encrypted the file.
% decrypt -a aes -k ~/keyf/05.07.aes16 \ -i ~/enc/e.ticket.to.ride -o ~/d.ticket.to.ride |
In the following example, a file is encrypted with the ARCFOUR algorithm. The ARCFOUR algorithm accepts a key of 8 bits (1 byte), 64 bits (8 bytes), or 128 bits (16 bytes).
% encrypt -a arcfour -i personal.txt \ -k ~/keyf/05.07.rc4.8 -o ~/enc/e.personal.txt |
% decrypt -a arcfour -i ~/enc/e.personal.txt \ -k ~/keyf/05.07.rc4.8 -o ~/personal.txt |
In the following example, a file is encrypted with the 3DES algorithm. The 3DES algorithm requires a key of 192 bits, or 24 bytes.
% encrypt -a 3des -k ~/keyf/05.07.des24 \ -i ~/personal2.txt -o ~/enc/e.personal2.txt |
% decrypt -a 3des -k ~/keyf/05.07.des24 \ -i ~/enc/e.personal2.txt -o ~/personal2.txt |
The following messages indicate that the key that you provided to the encrypt command is not permitted by the algorithm that you are using.
encrypt: unable to create key for crypto operation: CKR_ATTRIBUTE_VALUE_INVALID
encrypt: failed to initialize crypto operation: CKR_KEY_SIZE_RANGE
If you pass a key that does not meet the requirements of the algorithm, you must supply a better key.
One option is to use a passphrase. The framework then provides a key that meets the requirements.
The second option is to pass a key size that the algorithm accepts. For example, the DES algorithm requires a key of 64 bits. The 3DES algorithm requires a key of 192 bits.
