This section describes how to administer the software providers and the hardware providers in the Solaris Cryptographic Framework. Software providers and hardware providers can be removed from use when desirable. For example, you can disable the implementation of an algorithm from one software provider. You can then force the system to use the algorithm from a different software provider.
The Solaris Cryptographic Framework provides algorithms for several types of consumers:
User-level providers provide a PKCS #11 cryptographic interface to applications that are linked with the libpkcs11 library
Kernel software providers provide algorithms for IPsec, Kerberos, and other Solaris kernel components
Kernel hardware providers provide algorithms that are available to kernel consumers and to applications through the pkcs11_kernel library
List the providers in a brief format.
The contents and format of the providers list varies for different Solaris releases. Run the cryptoadm list command on your system to see the providers that your system supports.
Only those mechanisms at the user level are available for use by regular users.
% cryptoadm list
user-level providers:
/usr/lib/security/$ISA/pkcs11_kernel.so
/usr/lib/security/$ISA/pkcs11_softtoken.so
kernel software providers:
des
aes
blowfish
arcfour
sha1
md5
rsa
kernel hardware providers:
ncp/0
List the providers and their mechanisms in the Solaris Cryptographic Framework.
All mechanisms are listed in the following output. However, some of the listed mechanisms might be unavailable for use. To list only the mechanisms that the administrator has approved for use, see Example 14–16.
The output is reformatted for display purposes.
% cryptoadm list -m user-level providers: ===================== /usr/lib/security/$ISA/pkcs11_kernel.so: CKM_MD5,CKM_MD5_HMAC, CKM_MD5_HMAC_GENERAL,CKM_SHA_1,CKM_SHA_1_HMAC,CKM_SHA_1_HMAC_GENERAL, … /usr/lib/security/$ISA/pkcs11_softtoken.so: CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN, CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN, CKM_AES_CBC,CKM_AES_CBC_PAD,CKM_AES_ECB,CKM_AES_KEY_GEN, … kernel software providers: ========================== des: CKM_DES_ECB,CKM_DES_CBC,CKM_DES3_ECB,CKM_DES3_CBC aes: CKM_AES_ECB,CKM_AES_CBC blowfish: CKM_BF_ECB,CKM_BF_CBC arcfour: CKM_RC4 sha1: CKM_SHA_1,CKM_SHA_1_HMAC,CKM_SHA_1_HMAC_GENERAL md5: CKM_MD5,CKM_MD5_HMAC,CKM_MD5_HMAC_GENERAL rsa: CKM_RSA_PKCS,CKM_RSA_X_509,CKM_MD5_RSA_PKCS,CKM_SHA1_RSA_PKCS swrand: No mechanisms presented. kernel hardware providers: ========================== ncp/0: CKM_DSA,CKM_RSA_X_509,CKM_RSA_PKCS,CKM_RSA_PKCS_KEY_PAIR_GEN, CKM_DH_PKCS_KEY_PAIR_GEN,CKM_DH_PKCS_DERIVE,CKM_EC_KEY_PAIR_GEN, CKM_ECDH1_DERIVE,CKM_ECDSA |
In the following example, all mechanisms that the user-level library, pkcs11_softtoken, offers are listed.
% cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so Mechanisms: CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN, CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN, … CKM_SSL3_KEY_AND_MAC_DERIVE,CKM_TLS_KEY_AND_MAC_DERIVE |
Policy determines which mechanisms are available for use. The administrator sets the policy. An administrator can choose to disable mechanisms from a particular provider. The -p option displays the list of mechanisms that are permitted by the policy that the administrator has set.
% cryptoadm list -p user-level providers: ===================== /usr/lib/security/$ISA/pkcs11_kernel.so: all mechanisms are enabled. random is enabled. /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled. random is enabled. kernel software providers: ========================== des: all mechanisms are enabled. aes: all mechanisms are enabled. blowfish: all mechanisms are enabled. arcfour: all mechanisms are enabled. sha1: all mechanisms are enabled. md5: all mechanisms are enabled. rsa: all mechanisms are enabled. swrand: random is enabled. kernel hardware providers: ========================== ncp/0: all mechanisms are enabled. |
Assume the Primary Administrator role, or become superuser.
The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
List the software providers that are available to the system.
% cryptoadm list
des
aes
blowfish
arcfour
sha1
md5
rsa
ncp/0
Add the provider's package by using the pkgadd command.
# pkgadd -d /path/to/package pkginst |
The package must include software that has been signed by a certificate from Sun. To request a certificate from Sun and to sign a provider, see Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
The package should have scripts that notify the cryptographic framework that another provider with a set of mechanisms is available. For information about the packaging requirements, see Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
Refresh the providers.
You need to refresh providers if you added a software provider, or if you added hardware and specified policy for the hardware.
# svcadm refresh svc:/system/cryptosvc |
Locate the new provider on the list.
In this case, a new kernel software provider was installed.
# cryptoadm list
des
aes
blowfish
arcfour
sha1
md5
rsa
swrand
ecc <-- added provider
In the following example, a signed PKCS #11 library is installed.
# pkgadd -d /cdrom/cdrom0/SolarisNew
Answer the prompts
# svcadm refresh system/cryptosvc
# cryptoadm list
/opt/SUNWconn/lib/$ISA/libpkcs11.so.1 <-- added provider
Developers who are testing a library with the cryptographic framework can install the library manually.
# cryptoadm install provider=/opt/SUNWconn/lib/\$ISA/libpkcs11.so.1 |
For information on getting your provider signed, see Binary Signatures for Third-Party Software.
If some of the cryptographic mechanisms from a library provider should not be used, you can remove selected mechanisms. This procedure uses the DES mechanisms in the pkcs11_softtoken library as an example.
Become superuser or assume a role that includes the Crypto Management rights profile.
To create a role that includes the Crypto Management rights profile and assign the role to a user, see Example 9–7.
List the mechanisms that are offered by a particular user-level software provider.
% cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN, CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN, CKM_AES_CBC,CKM_AES_CBC_PAD,CKM_AES_ECB,CKM_AES_KEY_GEN, … |
List the mechanisms that are available for use.
$ cryptoadm list -p user-level providers: ===================== … /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled. random is enabled. … |
Disable the mechanisms that should not be used.
$ cryptoadm disable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so \ > mechanism=CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB |
$ cryptoadm list -p provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled, except CKM_DES_ECB,CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled. |
In the following example, a disabled DES mechanism is again made available for use.
$ cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN, CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN, … $ cryptoadm list -p provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled, except CKM_DES_ECB,CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled. $ cryptoadm enable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so \ > mechanism=CKM_DES_ECB $ cryptoadm list -p provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled, except CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled. |
In the following example, all mechanisms from the user-level library are enabled.
$ cryptoadm enable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so all $ cryptoadm list -p provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled. random is enabled. |
In the following example, the libpkcs11.so.1 library is removed.
$ cryptoadm uninstall provider=/opt/SUNWconn/lib/\$ISA/libpkcs11.so.1
$ cryptoadm list
If the cryptographic framework provides multiple modes of a provider such as AES, you might remove a slow mechanism from use, or a corrupted mechanism. This procedure uses the AES algorithm as an example.
List the mechanisms that are offered by a particular kernel software provider.
$ cryptoadm list -m provider=aes aes: CKM_AES_ECB,CKM_AES_CBC |
$ cryptoadm list -p provider=aes aes: all mechanisms are enabled. |
Disable the mechanism that should not be used.
$ cryptoadm disable provider=aes mechanism=CKM_AES_ECB |
$ cryptoadm list -p provider=aes aes: all mechanisms are enabled, except CKM_AES_ECB. |
In the following example, a disabled AES mechanism is again made available for use.
cryptoadm list -m provider=aes aes: CKM_AES_ECB,CKM_AES_CBC $ cryptoadm list -p provider=aes aes: all mechanisms are enabled, except CKM_AES_ECB. $ cryptoadm enable provider=aes mechanism=CKM_AES_ECB $ cryptoadm list -p provider=aes aes: all mechanisms are enabled. |
In the following example, the AES provider is temporarily removed from use. The unload subcommand is useful to prevent a provider from being loaded automatically while the provider is being uninstalled. For example, the unload subcommand would be used when installing a patch that affects the provider.
$ cryptoadm unload provider=aes |
$ cryptoadm list
des
aes (inactive)
blowfish
arcfour
sha1
md5
rsa
swrand
The AES provider is unavailable until the cryptographic framework is refreshed.
$ svcadm refresh system/cryptosvc |
$ cryptoadm list
des
aes
blowfish
arcfour
sha1
md5
rsa
swrand
If a kernel consumer is using the kernel software provider, the software is not unloaded. An error message is displayed and the provider continues to be available for use.
In the following example, the AES provider is removed from use. Once removed, the AES provider does not appear in the policy listing of kernel software providers.
$ cryptoadm uninstall provider=aes |
$ cryptoadm list
des
blowfish
arcfour
sha1
md5
rsa
swrand
If a kernel consumer is using the kernel software provider, an error message is displayed and the provider continues to be available for use.
In the following example, the AES kernel software provider is reinstalled.
$ cryptoadm install provider=aes mechanism=CKM_AES_ECB,CKM_AES_CBC |
$ cryptoadm list
des
aes
blowfish
arcfour
sha1
md5
rsa
swrand
Hardware providers are automatically located and loaded. For more information, see driver.conf(4) man page.
When you have hardware that expects to be used within the Solaris Cryptographic Framework, the hardware registers with the SPI in the kernel. The framework checks that the hardware driver is signed. Specifically, the framework checks that the object file of the driver is signed with a certificate that Sun issues.
For example, the Sun Crypto Accelerator 6000 board (mca), the ncp driver for the cryptographic accelerator on the UltraSPARC T1 and T2 processors (ncp), and the n2cp driver for the UltraSPARC T2 processors (n2cp) plug hardware mechanisms into the framework.
List the hardware providers that are available on the system.
% cryptoadm list … kernel hardware providers: ncp/0 |
List the mechanisms that the chip or the board provides.
% cryptoadm list -m provider=ncp/0 ncp/0: CKM_DSA,CKM_RSA_X_509,CKM_RSA_PKCS,CKM_RSA_PKCS_KEY_PAIR_GEN, CKM_DH_PKCS_KEY_PAIR_GEN,CKM_DH_PKCS_DERIVE,CKM_EC_KEY_PAIR_GEN, CKM_ECDH1_DERIVE,CKM_ECDSA |
List the mechanisms that are available for use on the chip or the board.
% cryptoadm list -p provider=ncp/0 ncp/0: all mechanisms are enabled. |
You can selectively disable mechanisms and the random number feature from a hardware provider. To enable them again, see Example 14–25. The hardware in this example, the Sun Crypto Accelerator 1000 board, provides a random number generator.
Choose the mechanisms or feature to disable.
List the hardware provider.
# cryptoadm list
Kernel hardware providers:
dca/0
Disable selected mechanisms.
# cryptoadm list -m provider=dca/0 dca/0: CKM_RSA_PKCS, CKM_RSA_X_509, CKM_DSA, CKM_DES_CBC, CKM_DES3_CBC random is enabled. # cryptoadm disable provider=dca/0 mechanism=CKM_DES_CBC,CKM_DES3_CBC # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled except CKM_DES_CBC,CKM_DES3_CBC. random is enabled. |
Disable the random number generator.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled. random is enabled. # cryptoadm disable provider=dca/0 random # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled. random is disabled. |
Disable all mechanisms. Do not disable the random number generator.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled. random is enabled. # cryptoadm disable provider=dca/0 mechanism=all # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are disabled. random is enabled. |
Disable every feature and mechanism on the hardware.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled. random is enabled. # cryptoadm disable provider=dca/0 all # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are disabled. random is disabled. |
In the following examples, disabled mechanisms on a piece of hardware are selectively enabled.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled except CKM_DES_ECB,CKM_DES3_ECB |
. random is enabled. # cryptoadm enable provider=dca/0 mechanism=CKM_DES3_ECB # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled except CKM_DES_ECB. random is enabled. |
In the following example, only the random generator is enabled.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled, except CKM_MD5,CKM_MD5_HMAC,…. random is disabled. # cryptoadm enable provider=dca/0 random # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled, except CKM_MD5,CKM_MD5_HMAC,…. random is enabled. |
In the following example, only the mechanisms are enabled. The random generator continues to be disabled.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled, except CKM_MD5,CKM_MD5_HMAC,…. random is disabled. # cryptoadm enable provider=dca/0 mechanism=all # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled. random is disabled. |
In the following example, every feature and mechanism on the board is enabled.
# cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled, except CKM_DES_ECB,CKM_DES3_ECB. random is disabled. # cryptoadm enable provider=dca/0 all # cryptoadm list -p provider=dca/0 dca/0: all mechanisms are enabled. random is enabled. |
By default, the Solaris Cryptographic Framework is enabled. When the kcfd daemon fails for any reason, the service management facility can be used to restart cryptographic services. For more information, see the smf(5) and svcadm(1M) man pages. For the effect on zones of restarting cryptographic services, see Cryptographic Services and Zones.
Check the status of cryptographic services.
% svcs cryptosvc STATE STIME FMRI offline Dec_09 svc:/system/cryptosvc:default |
Become superuser or assume an equivalent role to enable cryptographic services.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map).
# svcadm enable svc:/system/cryptosvc |
In the following example, cryptographic services are refreshed in the global zone. Therefore, kernel-level cryptographic policy in every non-global zone is also refreshed.
# svcadm refresh system/cryptosvc |
