Table 2–3 lists the UNIX directories used to store NIS+ files.
Table 2–3 Where NIS+ Files Are Stored| Directory | Where | Contains |
| /usr/bin | All machines | NIS+ user commands |
| /usr/lib/nis | All machines | NIS+ administrator commands |
| /usr/sbin | All machines | NIS+ daemons |
| /usr/lib/ | All machines | NIS+ shared libraries |
| /var/nis/data | NIS+ server | Data files used by NIS+ server |
| /var/nis | NIS+ server | NIS+ working files |
| /var/nis | NIS+ client machines | Machine-specific data files used by NIS+ |
 Caution –
Caution – Do not rename the /var/nis or /var/nis/data directories or any of the files in these directories that were created by nisinit or any of the other NIS+ setup procedures. In the Solaris 2 release, the /var/nis directory contained two files named hostname.dict and hostname.log. It also contained a subdirectory named /var/nis/hostname.
Starting with the Solaris 2.5 release, the two files were named trans.log and data.dict, and the subdirectory was named /var/nis/data. The content of the files was also changed, so these files are not backward compatible with earlier releases. Thus, if you rename either the directories or the files to match the Solaris 2.4 patterns, the files will not work with either the Solaris 2.4 release or the current version of the rpc.nisd daemon. Therefore, do not rename either the directories or the files.
With the Solaris platform, the NIS+ data dictionary (/var/nis/data.dict) is now machine independent. This allows you to easily change the name of an NIS+ server. You can also now use the NIS+ backup and restore capabilities to transfer NIS+ data from one server to another. See Chapter 21, NIS+ Backup and Restore.
