The open(9E) entry point is used to gain access to a given device. The open(9E) routine of a block driver is called when a user thread issues an open(2) or mount(2) system call on a block special file associated with the minor device, or when a layered driver calls open(9E). See File I/O for more information.
The open() entry point should check for the following conditions:
The device can be opened, that is, the device is online and ready.
The device can be opened as requested. The device supports the operation. The device's current state does not conflict with the request.
The caller has permission to open the device.
The following example demonstrates a block driver open(9E) entry point.
static int
xxopen(dev_t *devp, int flags, int otyp, cred_t *credp)
minor_t instance;
struct xxstate *xsp;
instance = getminor(*devp);
xsp = ddi_get_soft_state(statep, instance);
if (xsp == NULL)
return (ENXIO);
mutex_enter(&xsp->mu);
* only honor FEXCL. If a regular open or a layered open
* is still outstanding on the device, the exclusive open
* must fail.
if ((flags & FEXCL) && (xsp->open || xsp->nlayered)) {
mutex_exit(&xsp->mu);
return (EAGAIN);
switch (otyp) {
case OTYP_LYR:
xsp->nlayered++;
break;
case OTYP_BLK:
xsp->open = 1;
break;
default:
return (EINVAL);
return (0);
The otyp argument is used to specify the type of open on the device. OTYP_BLK is the typical open type for a block device. A device can be opened several times with otyp set to OTYP_BLK. close(9E) is called only once when the final close of type OTYP_BLK has occurred for the device. otyp is set to OTYP_LYR if the device is being used as a layered device. For every open of type OTYP_LYR, the layering driver issues a corresponding close of type OTYP_LYR. The example keeps track of each type of open so the driver can determine when the device is not being used in close(9E).
