The property functions are:
Check for the existence of a property
Free resources consumed by property lookup
Look up integer property
Look up 64-bit integer property
Look up byte array property
Look up integer array property
Look up 64-bit integer array property
Look up string property
Look up string array property
Remove a property of a device
Remove all properties of a device
Hide a property of a device
Create or update byte array property
Create or update integer property
Create or update 64-bit integer property
Create or update integer array property
Create or update 64-bit integer array property
Create or update string property
Create or update string array property
Deprecated Functions |
Replacements |
ddi_getlongprop() |
see ddi_prop_lookup() |
ddi_getlongprop_buf() |
ddi_prop_lookup() |
ddi_getprop() |
ddi_prop_get_int() |
ddi_getproplen() |
ddi_prop_lookup() |
ddi_prop_create() |
ddi_prop_lookup() |
ddi_prop_modify() |
ddi_prop_lookup() |
ddi_prop_op() |
ddi_prop_lookup() |
