Writing Device Drivers
User Space Access Functions
The user space access functions are:
ddi_copyin()
Copy data to a driver buffer
ddi_copyout()
Copy data from a driver
uiomove()
Copy kernel data using a uio structure
ureadc()
Add character to a uio structure
uwritec()
Remove a character from a uio structure
getminor()
Get minor device number.
ddi_model_convert_from()
Determine a data model type mismatch
IOC_CONVERT_FROM()
Determine whether there is a need to translate M_IOCTL contents
STRUCT_DECL()
Establish the handle to application data in a possibly differing data model
STRUCT_HANDLE()
STRUCT_INIT()
STRUCT_SET_HANDLE()
SIZEOF_PTR()
Return the size of pointer in specified data model
SIZEOF_STRUCT()
Return the size of a structure in the specified data model
STRUCT_SIZE()
Return the size of a structure in the application data model
STRUCT_BUF()
Return a pointer to the native mode instance of the structure
STRUCT_FADDR()
Return a pointer to the specified field of a structure
STRUCT_FGET()
Return the specified field of a structure in the application data model
STRUCT_FGETP()
Return the specified pointer field of a structure in the application data model
STRUCT_FSET()
Set a specified field of a structure in the application data model
STRUCT_FSETP()
Set a specified pointer field of a structure in the application data model
Table B–6 Deprecated User Space Access Functions
Deprecated Function
Replacement
copyin()
ddi_copyin()
copyout()
ddi_copyout()
ddi_getminor()
getminor()
